#1 |
What wood glue?
I need to remove 1/4"x1" trim and install 1"x1" on the my front door frame in order to give the tollerances needed to hang a stormdoor I have a small window of warm weather 45 high to 35 low later this week. My ? is what glue would work best for the frame to trim joint ?
#2 |
What wood glue?
If you are going to glue it, I like polyurethane glue, such as gorilla glue. It fills joints nicely and is waterproof.
#3 |
What wood glue?
I am going to use a brad nailer to attach the trim but a little glue seems like a good idea. It looks like the storm door attaches to the trim not the door frame?
#4 |
What wood glue?
you don't need glue. Use exterior screws and caulk the edges after
#5 |
What wood glue?
Tightbond III is the only wood glue I'd use for exterior work.
Email: the to-do list anyone in the world can add items too. |
#6 |
A door a day is all I ask
What wood glue?
I think you might want your filler board to be wider than 1" (3/4" net or are you milling it?).
to avoid having it split when you put all of those screws in through the flanges.
Richard The Door Guy To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
What wood glue?
The J-channel is butted tight around the door and the 1x.25" trim so I have only 1" to work with. According to the stormdoor install. booklet I need 1" of with for the flange and 1" of depth for clearance for the door it's self. The problem is I only have about 5/8 depth with the 1"x.25" trim that's there so I have found 1"x1" stock that is going give me the clearance's required. This is the result bad planing and lack of understanding on my part I could have removed the old trim and replaced it with brickmold before the siding was installed thus solving the problem but.........
The new trim is a true 1"x1" so give me all the pointers that a door guy can please. |
#8 |
What wood glue?
Sounds like you are on the right track.
I am glad that your instructions say that you only need 1" for the flange. I guess I had it in my mind that it needed to be wider...It's been a while. Can you get that 1x1 in fir or is it only in pine? I think fir would hold the screws better. Drilling small pilot holes for the screws would help the boards tend not to split. Smaller holes in pine because it is softer. Regarding glue: I guess I am a titebond fan also...No personal experience with the polyurethane glues...I know they are popular. If you are only nailing with a brad nailer I would definitely glue it also. As Mrgins said, screws would be a help especially near hinges and latches. Pre drill and counter sink screws. Regarding exterior wood trim: seal the end grain of any boards that will get wet to avoid rot and peeling paint in the future. I use exterior glue as sealer on the tops and bottoms of my exterior doors. Hope that helps a bit.
#9 |
What wood glue?
The 1"x1" I have is pine if I glue it and screw it will it be strong enough ? Or should I search for fir
#10 |
What wood glue?
The pine is probably fine....Just keep your screw pilot holes small enough so that the
screws have plenty of material to create the threads and therefore holding power.
#11 |
What wood glue?
Just for the sake of knowing how is the stormdoor frame attached to entery door frame, is screwed into the frame from the inside or face screwed ? Second question is the hinge like a piano hinge and about how many screws attach the hinge side of the frame ? And lastly would 2" screws pre-drilled and counter sunk every 12" be adequate to attach the 1"x1" trim if also glued ?
#12 |
What wood glue?
1. Mostly face screwed but with a screw hole (or two) by each hinge inside the opening.
2. It is a piano hinge. 3. More than adequate on your proposed screw layout.
| The Following User Says Thank You to TheDoorGuy For This Useful Post: | STL B. (01-14-2011) |
#13 |
What wood glue?
Well door guy they are in and lookin good and it was very easy. They are emco doors front and back costing around $400 total with the trim/screws and caulk. It took about 2hr for the cheaper rear door and I could have finished the front in 1.5hr if it wasnt for the 3/4" drill bit(that I didn't have) for the lock set so I took a beer break and went to lowes for a $30 taper bit and finished soon there after. So thank you sir for the tips and advice It could'nt have went any better.
| The Following User Says Thank You to STL B. For This Useful Post: | TheDoorGuy (01-14-2011) |
#14 |
What wood glue?
Thanks for the update B...Glad it went well.
Sounds like you made good time on them too... You should add that to your business card!! Judging from intellicast weather it looks like storm doors are definitely in order in St Louis this week!! RC/DG
#15 | |
What wood glue?Quote:
| Tags |
glue ![]() |
| Display Modes | |
| Glue and staple engineered wood on stair treads? | cej22 | Flooring | 1 | 09-23-2009 11:13 AM |
| Which Is Better - Wood Glue OR Liquid Nails? | JackOfAllTrades | Carpentry | 10 | 09-16-2009 03:02 PM |
| joist sistering | norriselijah@yahoo.com | Building & Construction | 9 | 09-24-2008 10:18 PM |
| Removing floor tile glue from a wood floor | mrmordun | Flooring | 2 | 09-03-2008 10:41 PM |
| Wood close to Non-IC recessed lighting-solution? | sjmonty | Electrical | 4 | 12-01-2006 10:14 AM |
