What Wood For A BIG Entertainment Unit/Fish Tank?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-09-2009, 04:43 AM   #1
Lightbulb
What wood for a BIG entertainment unit/Fish Tank??
Hello folks, Im looking into building an entertainment unit. Its gonna be approx 6 feet high and 5 foot wide. The catch is, im putting a 5 foot fish tank along the top of it!! The ank will be about 50cm high and about 50-80cm front-back. I understand the engineering to go into it, THATS ALOT OF WATER weight i know. but what wud be a very good strong wood that u cud reccomend. I need a wood that when it has the tank ontop of it can resist buckling even the slightest bit. This is a MASSIVe project so im not rushing into it or anythin but im tryin to get my research done. any help u have wud be a great help thanks. Any suggestions or ideas are welcome:-)
colmmc182 is offline   Reply With Quote
Old 06-09-2009, 06:32 AM   #2
the Musigician
DangerMouse's Avatar
yup, lotsa weight there, fer sure.... you'll need to look at the floor where it's gonna set too! is the structure strong enough to hold it?
a rough sketch of what you want to build could help to determine the stress factors involved. more weight will be added by a heavy TV and/or stereo equipment as well.
DM
Old 06-09-2009, 07:39 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
I would certainly use a hardwood like oak. Practically any hardwood will carry the weight if it's engineered correctly. You'll need some massive supports to carry that much water in a concentrated area.
Old 06-09-2009, 07:47 AM   #4
the Musigician
gee, and here i was gonna say OSB and balsa wood..... lol
DM
Old 06-09-2009, 08:21 AM   #5
Old School
cabinetman's Avatar
A rough sketch of the overall size and what will be fitted will help in the best method of fabrication and materials that can be used. If properly constructed with bracing to prevent racking and twisting, it doesn't have to be "overbuilt".
Some of the details that would help include the basic look desired, and if a wood finish, what species may be applicable, whether it will be painted or what other finishes are considered.
cabinetman is offline   Reply With Quote
Old 06-09-2009, 09:17 AM   #6
I typed up a response to your last post
But your post & my reply seem to be gone
50cm = 20", 80 = ~32"
A 6' tank 20" tall & 32" front to back is about 166 gallons
166 * 8.34 = ~1385 pounds
You will need to have support under the floor
Beam support on top to support the tank
Is this going on a concerte slab? 1st floor?
I have a 125g tank sitting on top of a main beam in the house
But its only 33" off the floor
Old 06-09-2009, 09:37 AM   #7
the Musigician
yup, like dave says, that's going to be a LOT of weight.... be sure it rock solid under it!!! i'd hate to have to clean up THAT mess if it fails!
if it were me, i'd think about using LVLs to support the tank and build around it.
design the bracing first, then think about the rest. using hidden LVLs could keep the cost for the rest a bit cheaper as well, as you could then use any wood to wrap the frame... but then again, the LVL is pretty expensive! owell.... just bouncin' ideas....
DM
What wood for a BIG entertainment unit/Fish Tank??-lvlframe.jpg
Old 06-09-2009, 09:47 AM   #8
I'd also use 3/4" plywood on the back for added strength
Properly designed it will work
Myself I'd rather have it lower & have the TV sit on top of it
Keep in mind you need to add water & change out water
and water over expensive electrical......bad idea
Old 06-09-2009, 09:56 AM   #9
the Musigician
that's funny.... that was my first mental picture... using a step stool to feed the fish.... lol
and draining and cleaning is gonna be fun.....
DM
Old 06-10-2009, 11:17 PM   #10
Wolf
Remarks about weight and how to handle this during construction have been fleshed out pretty well by others. As an electrical engineer experienced with audio gear, I have to say that putting that much water above an expensive entertainment center seems like an invitation to disaster to me. Leaks, spillage during cleaning and maintenance, refilling... the water will always travel downward. Think through this very carefully so an unsafe condition isn't created.
ralphfravel is offline   Reply With Quote
Old 06-11-2009, 08:31 AM   #11
Yeah, my hippo tang actually splashes water out of the tank
Usually when he wants some food
I have a hood on the tank, the water still drips down the sides
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
