What Width Of Crown Molding? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 01:42 PM   #1
what width of crown molding?
I have 8 ft ceilings. What is the guideline for what width of crown molding I should use based on the height of ceilings?
I am considering using 3-5/8" or 4-1/4" wide. Which size should I go with?
If it matters, my baseboards are 4-1/2" wide.
billyg is offline   Reply With Quote
Old 03-06-2009, 07:39 PM   #2
Old School
Willie T's Avatar
Here are some of those "Rules of Thumb" you hear so much about......
7 foot ceiling - 3" or smaller
8 foot ceiling - 3"- 4"
9 foot ceiling - 4" - 5"
10 foot ceiling - 6"
17 foot ceiling - 8" or larger
Personally, I don't agree with these sizes... I like bigger. And of course the style and the intricacy of any pattern have to come into consideration. As does the relationship to the size of the baseboard in the room.
Willie T
Old 03-07-2009, 06:10 AM   #3
Anywhere between 3 and 4" will look fine, but since you already have a "bigger" baseboard I'd go ahead with the 4 1/4". It will look great. Nothing bigger though. haha.
sausagefingers is offline   Reply With Quote
Old 03-07-2009, 06:59 AM   #4
SNC
I think 3 5/8 looks good on 8 foot walls, i would not go any bigger, in a small room i may go one size down.
SNC is offline   Reply With Quote
Old 03-07-2009, 09:29 AM   #5
Drywall contractor
Rewards Points: 1,070
I usually use 2-3/4" on 8' ceilings. Since you have the wide base, 3-5/8" would probably look better. The 4-1/2" might be a bit much. Get a couple of 6' samples and tack them up. Stand back and see what YOU think........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-07-2009, 03:45 PM   #6
Rewards Points: 5,336
How big is the room? I size crown molding based on both ceiling height and room size.
Ron
Old 03-07-2009, 06:19 PM   #7
Thanks for all the suggestions, guys.
RON...my room dimensions are as follows: Study 14'x11'x14'x11
Living 15'x14'x15'x14' Dining 12'x14'x12'x14'
Thanks.
Old 03-09-2009, 05:32 PM   #8
With those size rooms I think you're in the 3 5/8" -4 1/4 " range. As previously suggested, pick up a length of each and put them up. See which one you like.
Ron
Old 03-09-2009, 11:12 PM   #9
Rewards Points: 1,016
just did this
We just went through the same process for our 8' ceilings in a large open area - we decided the smaller samples looked better than the larger.
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
Door framing and crown molding finnishing question amdspitfire Painting 7 06-09-2008 01:49 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 07:11 AM
Crown Molding in the Kitchen Woody730 Remodeling 8 05-21-2008 06:17 AM
How to cut crown molding spyder9176 Carpentry 11 03-02-2008 09:58 AM
