What Type Of Hinge Should Be Used On A Celler Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 08:49 AM   #1
what type of hinge to use on a celler door so hinge dose not show on top of the floor?
can someone please tell me what type of hinge should be used on a celler door that is entered thru the kitchen floor?
sandrann is offline   Reply With Quote
Old 09-08-2010, 09:01 AM   #2
fabrk8r's Avatar
I'd use a piece of piano hinge mounted flush into the hinge side so the door can open 360 and lay flat on the floor so there would be no way it could fall shut and trap someone or knock them on the noggin.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
The Following User Says Thank You to fabrk8r For This Useful Post:
sandrann (09-08-2010)
Stripped out door hinge screws krankykitty Carpentry 23 01-16-2012 09:23 PM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Front Door - Door stops? 1655graff Carpentry 6 08-14-2009 12:40 PM
Help hanging a problematic door Termite Carpentry 12 07-21-2008 07:05 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
