Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-31-2010, 10:40 PM   #1
What tool ??? Need to cut out wood strips.
Decided I want to cut out 2 wood flooring strips to add a marble transition piece between floors in the picture below. Anyone have a tool they recommend using? A circular saw wont be able to cut all the way to the ends on each side. I don't know exactly what tool would be best to use or how exactly to proceed.
zman22 is offline   Reply With Quote
Old 03-31-2010, 10:56 PM   #2
Remodeling Contractor
a router then finish with a Fien Multimaster
Old 04-01-2010, 10:31 AM   #3
A "Handy Husband"
rjniles's Avatar
If you only need a tool for an occasional small job like this:
Harbor Freight oscillating tool (under $40).
It is a cheap knock-off of the Fein, but will do your job.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 04-01-2010, 11:25 AM   #4
jlhaslip's Avatar
skil saw set to depth.
rip cut the second one as far as you can near its middle.
finish the cut with a chisel.
the first one should be pullable by the time you get the second one out.
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 04-01-2010, 11:27 AM   #5
WOW, what a major difference in price for the tools. think I will get the "cheapo" special tool for this job.
So, I use a router to run along the length and then use the Fein tool to cut the 3 inches (or so) that will be left where the router wont reach. Is that the "jist" to this?
Old 04-02-2010, 08:36 AM   #6
all the above suggestions are good. Problem is the quality you are looking for. A saw will cut but it is harder to not splinter the existing wood. If using a router, go slow and set a guide so you are not trying to manually follow a line. Try borrowing a Fein Multimaster if you go this way. It will be easy to make a perfect cut. With the harbor freight tool it is nearly impossible. (this is why the cost difference) Now all of this is assuming you need to cut in the middle of one of the boards, if not, then even a chisel and prybar can be used. Also keep the spacing the same as the joints in the tile and use a sanded caulking to match your grout color. Do not place grout in this joint since it will surely crack.
The Following User Says Thank You to Bob Mariani For This Useful Post:
moorewarner (04-02-2010)
Old 04-08-2010, 11:10 AM   #7
Tool Cop
You can always check out the rockwell oscillating tool. It's more expensive than the harbor freight, but it'll last you a lot longer.
TrafficCopSmith is offline   Reply With Quote
Old 04-08-2010, 11:33 AM   #8
Thanks guys for all the suggestings.
I wound up purchasesing the Rockwell version of the Fien. It's probably not as good as the Fien, but appears to be well made and has the same blades for what I need at the moment.
Old 04-09-2010, 11:46 AM   #9
Jay123's Avatar
You'll have to let us know what you think of the rockler.
J
Jay
Jay123 is offline   Reply With Quote
Old 04-09-2010, 10:29 PM   #10
OK,
I have to say that I happen to LOVE this tool. So far I cut through some 3/4 plywood like butter. My hand was a little numb though due to the vibration it makes when I did a bunch of detailed cuts of the plywood. But, I did use it to cut off some shims used on another project that I could have handled all day without fatigue. This tool was absolutely perfect for that situation. Didnt cut out the floor yet, but will keep you posted soon.
Cant say I have any experience to compare this tool to the Fein, but it's a great tool IMO.
Old 04-12-2010, 09:03 AM   #11
[quote=zman22;426545]OK,
Vibrating tools can cause nerve damage in hands and fingers. Probably pros who use the tools daily are most at risk, but if you feel numbness, you should take a break.
zircon is offline   Reply With Quote
Old 04-12-2010, 09:19 AM   #12
Jay123's Avatar
I had carpel tunnel surgery done on both hands last year, but I've had years of using power sanders, etc.
I've had the fein multi-master for 6-7 years, and love it. Glad to see some other competition since their patent ran out, as fein's stuff is very expensive, especially for diy.
I've never regretted the $ for the fein, due to the fact that when you need it, you need it ...and it does a great job.
J
Jay
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Staining Wood - When to use wood filler markronz Carpentry 8 03-04-2010 08:15 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
