What Thickness Veneer For Pocket Door? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 08:31 PM   #1
What thickness veneer for pocket door?
Double pocket doors open from the master bath into the living room.
I'd like these door to be nicely finished, and limba wood is one of my favorites (but there are lots to choose from).
For you finish carpenters out there: what thickness of veneer do you recommend for a pocket type door?
The commercial pieces I see range from 1/8" to 1/42" thickness (pretty big spread there!)
The door is 2 inches thick.
Thanks!
Garrett
GarrettP1 is offline   Reply With Quote
Old 06-22-2011, 06:30 AM   #2
Most anything you apply would work in a normal 2x4 wall. The door slot opening is determined by the trim, so reset the trim for a wider opening.
Old 06-22-2011, 01:07 PM   #3
Thanks Bill.
My concern was more over the issue of delamination of the veneer over time.
I realize that application of the veneer is critical, but my experience has been that the thicker the veneer, the less warp and buckle over the surface.
Regards,
Garrett
Old 06-22-2011, 09:01 PM   #4
Since pocket doors get a lot of "abuse" and can be subject to warping, I would suggest using the thickest veneer you can get. The thicker veneer will survive hits and kicks, that would put a hole in thinner veneer.
foz1234 is offline   Reply With Quote
Can I shorten a Fiberglass door. rjniles Building & Construction 6 12-08-2010 12:57 PM
Rotten bottom plate and subfloor around exterior door deraj123 Building & Construction 5 08-13-2010 10:43 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
French Doors from Homedepot or Lowes??? johnnytuinals General DIY Discussions 47 01-10-2009 10:00 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
