Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-14-2008, 11:24 PM   #1
what thickness plywood for storage shelves?
I plan to make some storage shelves, using plywood as a backing. What thickness of plywood would be best for this? I plan to make the shelves around 60 or 70 inches high.
darsunt is offline   Reply With Quote
Old 08-15-2008, 07:34 AM   #2
gravity always wins
I would plan on using 3/4" minimum. Even then, the height is not the issue, it's the lenth of the shelf and the weight of the material you plan to store. 3-4 feet long is probably the maximum length for normal household storage shelves. If you plan to run plywood up a wall and attach brackets and shelves to it, then 3/4" for sure, and be certain it is well anchored to the wall.
Old 08-15-2008, 01:16 PM   #3
I plan to make them 36" long. The shelves will be 6" or 8" wide and they will have double 2X2 posts supporting them. Each unit will be (in theory at least) self supporting. It will be used to store fasteners, tape, plumbers putty, etc all the miscellaneous stuff for maintenance and repair work.
I will get the 3/4" plywood if necessary, but could I get away with thinner pieces?
Old 08-18-2008, 07:35 AM   #4
gravity always wins
Sure, if you don't mind a sag in the middle. Anything less than 3/4" will certainly sag, maybe even under it's own weight over time.
Old 08-18-2008, 08:17 AM   #5
Licensed Contractor
At only 6-8 inches wide, I would truely consider solid lumber shelves. Plywood would sag for sure, eventually, with any load at all.
If you are intent on use plywood, at least make a solid edging piece to stiffen the ply along its length. I recently made an inset cherry shelf unit for a client, using 1/2" cherry plywood to span the 28", but milled a solid cherry nosing for the front edge of the plywood. This greatly stiffens the shelf and helps to prevent sag. Although the edging I make are usually 'L' shaped in cross-section, even a solid strip glued and/or nailed to edge will also help.
Renovator,LLC is offline   Reply With Quote
Old 08-18-2008, 08:28 AM   #6
Whatamess
If you put a 1X1 1/2" rail under the front lip OSB or 1/2" plywood will hold a good load. Leave the shelf sticking out 3/4" and you can run the rail with one solid piece. I used OSB for mine.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
Plywood replacment FatAugie Roofing 3 09-04-2007 11:52 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
"Floating" shelves Freelancer Carpentry 7 03-05-2006 09:42 AM
