-   -   what thickness plywood for storage shelves? (http://www.diychatroom.com/f14/what-thickness-plywood-storage-shelves-25222/)
darsunt 08-14-2008 10:24 PM
I plan to make some storage shelves, using plywood as a backing. What thickness of plywood would be best for this? I plan to make the shelves around 60 or 70 inches high.
Maintenance 6 08-15-2008 06:34 AM
I would plan on using 3/4" minimum. Even then, the height is not the issue, it's the lenth of the shelf and the weight of the material you plan to store. 3-4 feet long is probably the maximum length for normal household storage shelves. If you plan to run plywood up a wall and attach brackets and shelves to it, then 3/4" for sure, and be certain it is well anchored to the wall.
darsunt 08-15-2008 12:16 PM
I plan to make them 36" long. The shelves will be 6" or 8" wide and they will have double 2X2 posts supporting them. Each unit will be (in theory at least) self supporting. It will be used to store fasteners, tape, plumbers putty, etc all the miscellaneous stuff for maintenance and repair work.
I will get the 3/4" plywood if necessary, but could I get away with thinner pieces?
Maintenance 6 08-18-2008 06:35 AM
Sure, if you don't mind a sag in the middle. Anything less than 3/4" will certainly sag, maybe even under it's own weight over time.
Renovator,LLC 08-18-2008 07:17 AM
At only 6-8 inches wide, I would truely consider solid lumber shelves. Plywood would sag for sure, eventually, with any load at all.
If you are intent on use plywood, at least make a solid edging piece to stiffen the ply along its length. I recently made an inset cherry shelf unit for a client, using 1/2" cherry plywood to span the 28", but milled a solid cherry nosing for the front edge of the plywood. This greatly stiffens the shelf and helps to prevent sag. Although the edging I make are usually 'L' shaped in cross-section, even a solid strip glued and/or nailed to edge will also help.
TazinCR 08-18-2008 07:28 AM
1 Attachment(s)
If you put a 1X1 1/2" rail under the front lip OSB or 1/2" plywood will hold a good load. Leave the shelf sticking out 3/4" and you can run the rail with one solid piece. I used OSB for mine.
