What Table Base Can Support A 3 1/2' X 7' Granite Slab Outdoors? - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 01:23 AM   #1
What table base can support a 3 1/2' x 7' granite slab outdoors?
I have a 3 1/2' x 7' bullnosed granite slab that I want to use as an outdoor table. What can I do for a table base that will support the weight of the slab?
Trici is offline   Reply With Quote
Old 04-21-2012, 12:49 AM   #2
CrossWorks's Avatar
Rewards Points: 150
This is an open ended question. it really depends what look your trying to achieve. Assuming that your granite piece probably weighs close to a 1000 lbs, I would build a base out of cement blocks and have stone work installed on the outside perimeter.
Or do something like this: http://www.suvstone.com/b/GAO035-Sto...le%20Bench.jpg
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-21-2012, 03:31 PM   #3
Rewards Points: 150
A 1 inch thick X 12 inch x 12 inch piece of granite weighs between 14 and 15 lbs.
goosebarry is offline   Reply With Quote
Old 04-21-2012, 08:32 PM   #4
CrossWorks's Avatar
Rewards Points: 150
Well, if you look at this picture which is on a job I was working on just a couple weeks ago, the upper granite slab is 4" thick 18" deep and roughly 7' wide. It took all of 7 men to get that slab which was estimated to be around 750 lbs hoisted to it's current location in this picture.
You may be correct with your dimensions, but if Trici's slab is 3-1/2" thick by 7' long and the depth we still don't know but can assume it to be at least 2' to used as a table, I'm pretty confident that 1000 lbs is not out of the question.
Old 04-22-2012, 10:19 AM   #5
Rewards Points: 160
i install granite everyday. 18" by 7' is probably only a few hundred pounds but you said it was 4" thick??? even so i highly doubt that is anywhere near 1000 lbs if 750 lbs
jhack836 is offline   Reply With Quote
Granite countertop corbel support question jxr Kitchen & Bath Remodeling 1 04-02-2012 02:05 PM
how to support flooring on a slab construction parker300 Flooring 4 08-31-2010 08:15 PM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 12:44 PM
What's the best mobile base for a table saw? RDS Tools 5 10-15-2008 09:54 AM
Pouring a concrete slab - Do I need a 4" gravel base? tokuzumi Building & Construction 2 11-27-2007 08:40 PM
