-   -   What table base can support a 3 1/2' x 7' granite slab outdoors? (http://www.diychatroom.com/f14/what-table-base-can-support-3-1-2-x-7-granite-slab-outdoors-140825/)
Trici 04-20-2012 12:23 AM
I have a 3 1/2' x 7' bullnosed granite slab that I want to use as an outdoor table. What can I do for a table base that will support the weight of the slab?
CrossWorks 04-20-2012 11:49 PM
This is an open ended question. it really depends what look your trying to achieve. Assuming that your granite piece probably weighs close to a 1000 lbs, I would build a base out of cement blocks and have stone work installed on the outside perimeter.
Or do something like this: http://www.suvstone.com/b/GAO035-Sto...le%20Bench.jpg
goosebarry 04-21-2012 02:31 PM
A 1 inch thick X 12 inch x 12 inch piece of granite weighs between 14 and 15 lbs.
CrossWorks 04-21-2012 07:32 PM
Well, if you look at this picture which is on a job I was working on just a couple weeks ago, the upper granite slab is 4" thick 18" deep and roughly 7' wide. It took all of 7 men to get that slab which was estimated to be around 750 lbs hoisted to it's current location in this picture.
http://www.diychatroom.com/[IMG]http...orks/photo.jpghttp://img.photobucket.com/albums/v8...orks/photo.jpg
You may be correct with your dimensions, but if Trici's slab is 3-1/2" thick by 7' long and the depth we still don't know but can assume it to be at least 2' to used as a table, I'm pretty confident that 1000 lbs is not out of the question.
jhack836 04-22-2012 09:19 AM
i install granite everyday. 18" by 7' is probably only a few hundred pounds but you said it was 4" thick??? even so i highly doubt that is anywhere near 1000 lbs if 750 lbs
