Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-29-2009, 05:06 PM   #1
Default what to support a reccessed shelf
On the partition wall I am setting up, I opened a "window" to have a reccessed shelf on one side. Basically, I will leave one side of the "window" open, without covering drywall, and the other side of the "window" covered. The window/recessed shelf is about 4'X5'.
Now the question is what should I use to add strength to the one sided open space? If I only use drywall on one side, people may just lean on the open side and break the drywall on the opposite side.
hohadcr is offline   Reply With Quote
Old 10-29-2009, 06:35 PM   #2
Is this going to be one big open space? If it is, I would back the drywall with a sheet of 1/2" birch plywood.
Ron
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip we would be laying out our permanent shelf. Going back to our drawing we have a permanent shelf that would complete our enclosure for our storage unit so we need to go ahead and measure for... Read More »
Here is the next screen; this is the welcome to the setup screen. It gives you in this case three different options; to set up Windows XP now press enter, to repair windows installation using the recovery CD press “r” or to quit all together... Read More »
Hi this is Jon on behalf of Expert Village in this video clip we would be laying out our shelves. Since we made each opening of our project the exact same size our shelves are all going to be the same in width. As I measure that opening I get 21 13/16... Read More »
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
How to Choose Drywall
How to Choose Drywall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about choosing drywall. There are a lot of different choices when you choose drywall. The drywall that I have chosen for this project is 5/8’s of an inch thick... Read More »
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 07:07 PM
Hanging shelf (mini "loft") from finished garage ceiling bdr Carpentry 6 12-01-2008 12:31 AM
How to add another support beam under floor joists LOStouten Carpentry 3 11-14-2008 12:55 AM
need help on repairing rotted deck support ga1990 Building & Construction 6 11-07-2008 09:32 PM
adjustable wall shelf rail amakarevic Building & Construction 1 10-31-2008 01:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
