What Size Rough Opening? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-22-2013, 06:59 PM   #1
Rewards Points: 992
What size rough opening?
I have a 24" and a 32" door I want to use together. What size rough opening should I have for them?
Hanging them as french doors, not prehung.
Toller is offline   Reply With Quote
Old 02-22-2013, 08:12 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
are you hanging them together as a pair or two seperate r.o's
woodworkbykirk is offline   Reply With Quote
Old 02-22-2013, 09:52 PM   #3
Rewards Points: 150
As a double pocket door, double sliding, separate, are they prehung??
kaschmid3 is offline   Reply With Quote
Old 02-23-2013, 11:02 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
measure the exact width of the doors. add 1 1/2" to each side to allow for jamb and space between jamb and framing and space between both doors. about a 59" RO for your situation
hand drive is offline   Reply With Quote
Old 02-23-2013, 11:16 AM   #5
Rewards Points: 150
First of all depends on doors per hung actual doors 2-0 or 20 in big difference
Old 02-23-2013, 12:31 PM   #6
3" is an awful lot of space to allow for shimming thats going to take a lot of shims.. typically 2 " will work if the r.o is perfectly square and level.. if not 2 1/2" is all thats needed
Old 02-23-2013, 04:24 PM   #7
Rewards Points: 150
Agreed I always go 2 1/4 bigger than door size.
Old 02-23-2013, 08:36 PM   #8
i would say about 58-1/2 if the doors will meet in the middle. that would give you an 1-1/8 on either side for plumbing the jambs and a 1/4 space between the doors in the middle.
Old 02-24-2013, 10:14 AM   #9
Rewards Points: 150
But if putting together will look wired because of different sizes might be easier just to buy a double prehung. Especially cause u would prob have to mortise for hinges . If they r old doors off of jambs and not per hung anymore they would have to be differing hinge sides to use and would need an astragal
Old 02-24-2013, 02:04 PM   #10
Rewards Points: 150
Toller said he is hanging them as pocket doors. With pocket doors the rough opening is twice the width of the doors plus 1" on each side, 114". The header will be 114" plus double jacks, total of 120". I usually put a stop up against each inside jack, frame my enclosing walls and trim the pocket with 3/4". Toller, are you using a pocket door track kit? Do you have a photo?
TheCamper is offline   Reply With Quote
Old 02-24-2013, 02:58 PM   #11
Rewards Points: 992
So I have had recommendation from 59 to 58.25. Does 58.5 seem okay?
Old 02-24-2013, 03:28 PM   #12
AHH, SPANS!!!
first post reads french doors actually
depends on jamb thickness and if you are building the RO yourself making it Plumb/Level etc... The RO for a 3/4" door frame with standard stop in a plumb-level opening should need- say 1/4" for close tolerances plus 3/4"(jamb), 3/16 (distance between door to jamb) so that is right at 1 3/16" added from the side of the door to the framing in the wall. do that twice plus add space between the two doors. that is close tolerances but if you are building it your self then is possible no doubt .
Old 02-25-2013, 06:00 AM   #13
Rewards Points: 150
If its not too expensive I would still do 2 same size doors ps don't forget to paint 4 sides of doors before installing
Old 02-25-2013, 06:55 AM   #14
Rewards Points: 992
I may live to regret it, but the 24" door is intended to remain shut, opening only for projects too big to get out a 32" door. Wall space will be at a premium, so I hate to waste 8" on a 32" door. I can always change to two 28" doors...
Old 02-25-2013, 07:23 AM   #15
Rewards Points: 150
Well good luck plan and prepare for everything a misstep in beginning turns into a real pain in the arse once sheet rocked ps be careful nailing base trim don't want to shoot door
average size door opening tiffaney Windows and Doors 4 10-19-2012 07:19 PM
Exterior Door - rough opening Question vasiejo Windows and Doors 3 09-19-2012 08:00 AM
Rough Opening deal Carpentry 4 02-25-2011 02:12 PM
Widen Rough Opening -- w/o a headache luvdairish Remodeling 7 06-11-2010 08:54 AM
exterior door frame size and rough opening kevincw01 Building & Construction 3 06-06-2010 08:26 AM
