What Size Nails Do I Need - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 07:50 AM   #1
what size nails do I need
I'm buying a Bostich framing nailer, and my first job I'll be using 2x3 studs. Should I buy 3" nails or smaller?
DIY Dummy is offline   Reply With Quote
Old 06-14-2009, 08:47 AM   #2
Rewards Points: 5,336
3" framing nails will be fine for partition walls for say, in a basement.
It would help when you post, you say what you're doing, not just the material you're using.
Sometimes the job will be inappropriate for the materials used and this way we can head off any misadventures in carpentry.
Ron
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
Reattaching baseboards? Joony Flooring 7 07-06-2008 09:11 AM
Rusty nails FatAugie Roofing/Siding 6 08-28-2007 10:25 AM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
