What Size Drywall? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-24-2008, 10:29 PM   #1
Question
What size Drywall?
I am going to be doing all new walls upstairs. And ceilings. I know drywall comes in 4x8 sizes. But what thickness should I use for the ceilings and walls? Do i use 1/2 Inch thick for ceilings? And less for walls?
Tdoggy187 is offline   Reply With Quote
Old 02-24-2008, 11:08 PM   #2
Rewards Points: 12
5/8 on the ceiling and 1/2 on the walls. Some even use 5/8 on the walls to give strength.
ponch37300 is offline   Reply With Quote
Old 02-24-2008, 11:10 PM   #3
Electrician
Around here its 1/2" all the way, especially if you hanging it by yourself...
chris75 is offline   Reply With Quote
Old 02-24-2008, 11:18 PM   #4
Rewards Points: 12
Alot of people do use 1/2 for everything which seems to be fine but it will show any waves or uneven framing alot more than 5/8.
Old 02-25-2008, 04:48 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
1/2" is all you need on the walls and ceilings.
There is a misundersanding that 5/8" sheetrock "sags less" on ceiling applications.
This is, in fact, true when the span is over 16" OC.
However, to imply that 1/2" sheetrock sags when attached 16" OC is a total myth.
We have installed 1/2" sheetrock (16" OC) on literally thousands of ceilings, with zero sagging.
- Build Well -
Old 02-25-2008, 11:46 AM   #6
Wink
sounds good
1/2 inch for walls and ceilings sounds good to me. Where I live they are having a sale on drywall. 4.99 a sheet! Is that good or what???
Even though I'm not starting the project just yet. I might have to buy all the drywall at 4.99 a sheet now!!!
Just got to figure out how much sheets I'm going to need now...hmmm...
Old 02-25-2008, 12:09 PM   #7
MA licensed remodeler
iremod's Avatar
Here in Mass we use 1/2" everywhere 90% of the time. Most of my jobs usually get a skim coat of plaster also.
@Tdog - $4.99/sheet is a good price for 4'x8' indeed.
iremod is offline   Reply With Quote
Old 02-25-2008, 02:27 PM   #8
Up here in Ontario, if the wall is attached to another property or if the wall is within 1 meter of your neighbour's house, you must use 5/8s drywall for that wall. Also if it's a multple unit dwelling, the ceilings must be 5/8 drywall.
adave is offline   Reply With Quote
Old 02-25-2008, 04:50 PM   #9
Rewards Points: 12
Good to know Atlantic
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 04:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 09:52 AM
Celing Drywall and Hurricane Clips Ricky D Building & Construction 2 04-09-2007 06:59 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
