What Are Sinkers Used For In Nails? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-11-2009, 07:30 PM   #1
What are sinkers used for in nails?
I am a complete carpentry novice and learning
gomerpyle is offline   Reply With Quote
Old 06-11-2009, 08:06 PM   #2
Old School
Willie T's Avatar
They are a little skinnier and just a tad (like 1/4") longer than common nails of the same diameter usage label.
Easier to drive because of the coating, be it vinyl or cement, and the cement coated are supposed to have better holding power. Simpson seems to think they are just the thing for some of their fasteners.
I personally think they are a pain to bother with. You're not supposed to use them in PT wood.
Willie T
Old 06-11-2009, 11:15 PM   #3
Registered User
Rewards Points: 4,914
They are the same length as a 12d common. To replace a 16d common, which is longer than a sinker by 1/4", you have to take a 16% reduction in load on hangers and straps. As per table at page bottom of page:
http://www.strongtie.com/products/connectors/nails.asp Be safe, G
Old 06-12-2009, 12:24 PM   #4
Rewards Points: 1,910
Nail terminology is downright stupid. Someone tells you to use 16ds for a project so you go into a store and they have 16D Common, Box and Sinkers. All are different diameters and/or length and have different load ratings (but none of that info is on the box).
For instance a 16d common is 0.162" x 3.5". A 16d sinker (0.148"x3.25") is actually the same diameter as both the 10d common and 12d common nails but longer than the 10d common (3") making it essentially a long 10d common or identical to a 12d common except for a very slight difference in the shape of the head. I wish they would throw it all out and go by diameter and length like they do for air gun nails.
The biggest problem with nail terminology is that people often don't give the full designation or understand it. So when the building department tells you need to use 16ds for your framing you need to ask "commons or sinkers?" Hopefully they don't give you a blank look back.
Here is a nice article on nails:
http://www.huduser.org/Publications/pdf/res2000_4.pdf
Old 06-12-2009, 01:42 PM   #5
Old School
Willie T's Avatar
My bad. I should have said "for the same use".
http://www.strongtie.com/ftp/bulleti...lguide02-r.pdf
Willie T
Forgot to use galvanized nails... healeypd Building & Construction 8 05-12-2009 10:10 AM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
Rusty nails FatAugie Roofing/Siding 6 08-28-2007 10:25 AM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 11:54 AM
Deck nails jimgibson Carpentry 12 10-09-2005 03:22 PM
