What Should I Do About Plywood Next To Drywall? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-27-2010, 10:19 PM   #1
Question
What should I do about plywood next to drywall?
We pulled down the 1970's paneling, and most of the walls are in good shape, just some patching, but above and below the bar is plywood, which is even with the drywall wall next to it and about an inch thick, we dont really want to pull all the plywood and drywall it, we need to figure out what to do with the plywood to match it up to the drywall all around it? Can We mud it? Do we prime it and skimcoat it? Whatever we do we are going to texture coat the whole room. Suggestions?? Please....
Debrralynn is offline   Reply With Quote
Old 11-27-2010, 10:41 PM   #2
the plywood won't be 1" thick. You could remove the top layer and replace it with drywall or you could mud it. If the plywood is painted, you'll need to sand the part of the plywood that will be taped so it sticks. You could also use a tapeable tearaway moulding in the joint between the existing drywall and the plywood, and then caulk the seam after it's been painted
mrgins is offline   Reply With Quote
Old 11-28-2010, 02:42 PM   #3
20 Year Veteran Carpenter
Tape & mud the seam(joint), finish joint just like drywall, sand it prime plywood and joint, paint both and forget it.
Kevin171 is offline   Reply With Quote
Tags
diy advice , drywall , mud , plywood
Attach Drywall through plywood HooKooDooKu Drywall & Plaster 2 01-20-2010 11:05 PM
Framing for Drywall Ceiling Wino Building & Construction 1 01-13-2010 03:05 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 03:30 PM
Hanging drywall Question avtck Drywall & Plaster 6 01-05-2010 07:21 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
