Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-28-2013, 02:51 PM   #1
What to put between the wood and tile?
Hey Guys,
I forgot to add a metal edge when tiling so now there is no straight egde...
What would you place between the wood transition piece and the tiles here?
Caulk (dap alex plus), silicone, buy some pre-made grout?? I feel that dirt and dust will get caught if I put nothing...
I'm going to secure it using silicone instead of the nails provided as I don't have to fill the nail holes and stain them.
What to put between the wood and tile?-20130128_144523.jpg   What to put between the wood and tile?-20130128_144530.jpg
sannitig is offline   Reply With Quote
Old 01-28-2013, 03:14 PM   #2
47_47's Avatar
I'd put in a matching color caulk.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
oh'mike (01-29-2013)
Old 01-28-2013, 03:59 PM   #3
Prestain and seal it before installing, use this to glue in place.
http://www.loctiteproducts.com/p/12/...n-Adhesive.htm
Use caulking at the seam.
Old 01-28-2013, 04:21 PM   #4
Yepp what he said ^^^^
pwgsx is offline   Reply With Quote
Old 01-28-2013, 05:19 PM   #5
Should be able to get caulking the same color as the grout.
Look in the tile area not the painting area.
Old 01-29-2013, 04:14 PM   #6
Awesome thanks!!!
I was going to PL but that is crazy permanent...that's why I was thinking of silicone in case I want/need to take it up in the future. You guys think Silicone won't hold?
Old 01-29-2013, 04:30 PM   #7
color matched caulk and finish nails for the strip and use a putty stick for the holes.
Old 01-29-2013, 06:17 PM   #8
get flexible grout the same color
princelake is offline   Reply With Quote
Old 01-29-2013, 06:35 PM   #9
Super Moderator
Originally Posted by sannitig View Post
Awesome thanks!!!
Silicone will hold that quite nicely if you wish to use it----
Old 01-30-2013, 08:05 AM   #10
gravity always wins
And don't get it on your socks. You'll track it onto your new flooring.
Old 01-30-2013, 01:10 PM   #11
If it's just a piece of T molding I'd just use clear silicone. I wouldn't worry about dirty and crud really getting stuck underneath. I did pretty much the exact same thing and just use silicone to attach my strip of T molding and it holds fine. Personally I don't like caulking the edge of the T molding because it's not as clean a look imo, unless you have a big gap you're trying to hide.
NewHomeDIYGuy is offline   Reply With Quote
Old 02-01-2013, 12:08 PM   #12
Flexible grout exists?
Old 02-01-2013, 12:11 PM   #13
Excellent.
When you say gap, do you mean the gap between the molding and floor? because this is't a T molding, it's more of a wedge (reducer). Eitherway the only gap I have is along the "not so straight edge" of the tile.
I wish I told my tiler to place a finished metal edge there.
Old 02-01-2013, 12:22 PM   #14
Ah ic.. Hard to tell by the picture it looked like the tile and HW floors are on the same height plane. Honestly it all comes down to aesthetics and what looks best imo. I laboured over worrying about the transition and it really wasn't a big deal after I did it. It's really hard to tell how big the gap is in between the tile/transition.. Is it sitting flush or is it not flat? If the transition isn't sitting flat then you'd need to cut the back of it w/ a table saw and very carefully rip it down slightly. If the transition sits very loosely in its spot you might need a couple nails as others suggested, but you could always try just siliconing it down in place and see how it looks. If the gap by the tile is too large caulk it afterwards. I've learned that basically you do whatever you gotta do to make it fit/look nice.
Edit: Looking at the pictures again if you caulk the transition/tile gap, I'm sure it'll look fine as long as you color match the caulk to the grout you have. Whether you need/want to caulk that gap is personal preference.
Also as others said.. if you want to stain it.. make sure you do it BEFORE installing the transition piece.
Old 02-01-2013, 12:29 PM   #15
It is flush now...after planing and sanding for like 2 hours...I didn't have a table saw.
I'm just going to silicone...put some dumbbells on it and leave it for 2 days. It's now stained and urethaned so I don't want to put any nails in it now, i assume.
I am going to look for flexible grout or matching caulk (whichever is cheaper)
Thanks for the help everyone.
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Wood baseboard and tile flooring Dave613 Flooring 1 06-02-2011 08:24 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 11:56 PM
