#1 |
What nails to use? 2x4 framing, osb sheathing
I'm adding a 12x24 addition to my existing garage with 2x4 walls & 2x6's running across for the roof. It's a "slant" roof like a awning.
Need help on what "size" & what "type" of nails to use. Doing it the old fashion way. Hammer & nails, NO nail gun. Walls: 1. 2x4 pressure treated sub plate 2. 2x4 doug fir top plates I was thinking 10d or 16d but don't no which one or what type. Don't want to split the 2x4's. I could blunt the nails. Do I use Common, Box, Sinker, Coated, Galvinized? I'm confused. 3. 2x4 trimmer studs nailed to king studs side by side or into headers. Same as above, what size & type? 4. 7/16" 4x8 OSB for wall sheating Same as above, I was thinking 8d or is that too long? What type and what is the spacing of nails. Is it every 6" around the edges & 12" on the center studs (16" o.c.)? 5. 1/2" 4x8 black/sound board applied next to match up thickness of existing garage. Not sure at all what size or type of nails to use. Is the nail spacing the same as the OSB? 6. 4x8 sheets of hardie/masonite siding applied next. Not sure what the standard thickness of the sheets is yet, probally 1/2" or less. Again what size & type of nails. Is the nail spacing the same as the OSB? 7. Also I might be using some different types of Simpson metal brackets for the 2x6 roof. What size nails & type or screws? The guys at the lumber box stores didn't have a straight answer on any of this, so I thought I would get some better advice from some experienced people on this board. |
#2 | |
Moderator
What nails to use? 2x4 framing, osb sheathingQuote:
#3 |
Framing Contractor
It depends where you're from. I frame with 8's every day toenailing studs. It's must be a regional thing.
Joe Carola |
#4 | ||
Framing Contractor
Depends on how you're framing the walls. Are you toenailing or endnailing? Quote:
Joe Carola |
#5 |
Moderator
What nails to use? 2x4 framing, osb sheathing |
#6 | |
BUILDER / REMODELING CONT
| Display Modes | |
| clipped FINISH vs. FRAMING nail | amakarevic | Building & Construction | 4 | 04-25-2008 04:46 PM |
| Best Practices for Framing Nail size | jms5883 | Remodeling | 7 | 01-31-2008 12:37 PM |
| sheathing nails | farrington135 | Building & Construction | 3 | 06-11-2007 11:17 AM |
| Which nails are right for the job? | MIKEGOUGH1 | Building & Construction | 2 | 12-16-2006 11:54 AM |
| Screws vs Nails in Interior framing project | alexz | Building & Construction | 2 | 07-05-2006 06:58 AM |
