What Kind Of Tool Is Needed To ..... - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-15-2012, 01:56 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What kind of tool is needed to .....
make inlays into wood? Is there a power tool for this or is it just done by hand?
Journeyman Plumber
Old 12-15-2012, 02:45 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
it depends on the size and detail of the inlay. if its large it can be done with a router and a guide.. if its small a knife and chisel usually work
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Alan (12-15-2012)
Old 12-15-2012, 03:06 PM   #3
Doing it myself
Alan's Avatar
Am I correct in assuming that the depth is not terribly critical?
It seems like if the channel in the main piece of wood is too small, a sander will make quick work of knocking it down.
I'm thinking about making my kid a "pokemon mat" as the ones that come with the game are paper and are getting destroyed quickly. I would basically be making a dozen small squares the sizes of cards..... Maybe a knife and a straight edge would be the way to go. I could make 1/4" channels and lay some darker wood into it.
Journeyman Plumber
Old 12-15-2012, 03:18 PM   #4
DIY staff
Rewards Points: 7,174
Do a Youtube search for 'router inlay'-----It's really rather simple---the router inlay set consists of two rub collars for the router and a small straight cutting bit---
You will need to make one template out of a scrap of MDF or plywood--this is used to cut the filler piece and the indentation to receive it----
I use this for removing knots and patching the void with a good bit of wood---
Alan (12-15-2012)
Old 12-16-2012, 01:22 PM   #5
Rewards Points: 810
They are also called template guide bushing and/or template cutting bushing. The router base hole is usually standard, but you may need to buy matching router base plate.
Work will be more accurate with the router.
carpdad is offline   Reply With Quote
Old 12-17-2012, 04:18 AM   #6
Hey every 1
9 dollars, 2 hours of my time, and I drove away. Your diagnosis was right on the mark. Thank you so much.
zeeshan is offline   Reply With Quote
What kind of cable is this? Sith717 Electrical 3 03-10-2012 01:56 PM
Which tool MattE Tools 12 03-16-2011 09:09 AM
Ryobi...The Throwaway Tool Company RainPure Tools 14 11-01-2009 08:05 PM
Starter tool kits cellophane Tools 16 10-13-2009 02:58 PM
the tool for mounting real short nipples amakarevic Plumbing 2 11-01-2008 12:34 AM
