-   -   What kind of tool is needed to ..... (http://www.diychatroom.com/f14/what-kind-tool-needed-166535/)
Alan 12-15-2012 01:56 PM
make inlays into wood? Is there a power tool for this or is it just done by hand?
woodworkbykirk 12-15-2012 02:45 PM
it depends on the size and detail of the inlay. if its large it can be done with a router and a guide.. if its small a knife and chisel usually work
Alan 12-15-2012 03:06 PM
Am I correct in assuming that the depth is not terribly critical?
It seems like if the channel in the main piece of wood is too small, a sander will make quick work of knocking it down.
I'm thinking about making my kid a "pokemon mat" as the ones that come with the game are paper and are getting destroyed quickly. I would basically be making a dozen small squares the sizes of cards..... Maybe a knife and a straight edge would be the way to go. I could make 1/4" channels and lay some darker wood into it.
oh'mike 12-15-2012 03:18 PM
Do a Youtube search for 'router inlay'-----It's really rather simple---the router inlay set consists of two rub collars for the router and a small straight cutting bit---
You will need to make one template out of a scrap of MDF or plywood--this is used to cut the filler piece and the indentation to receive it----
I use this for removing knots and patching the void with a good bit of wood---
carpdad 12-16-2012 01:22 PM
They are also called template guide bushing and/or template cutting bushing. The router base hole is usually standard, but you may need to buy matching router base plate.
Work will be more accurate with the router.
zeeshan 12-17-2012 04:18 AM
Hey every 1
9 dollars, 2 hours of my time, and I drove away. Your diagnosis was right on the mark. Thank you so much. :thumbup:
