What Kind Of Header - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-01-2008, 08:07 PM   #1
what kind of header
Ok, so I have the typical one story rambler style house. My master bedroom closet has a 24" door right now and I want to put in 48" bifold doors. I don't think the wall in question is a load bearing wall since the back wall of the closet is the center of the house (I won't be doing anything to this wall).
The 24" opening has a 4x4 header now. I'll be taking out the four 2x4s acting as the existing casing plus and additional 2x4 that's only 6" away from the edge of the closet.
What size header do I need to put in for this new opening? And do I need to add shorter 2x4s between the celing and the header for the 2x4s that I am removing?
Thanks in advance for any help I get!
rhinester is offline   Reply With Quote
Old 03-01-2008, 09:15 PM   #2
Custom Cabinet Maker
new header full length of opening. 56" opening, full stud plus jack stud on each end with a 50" opening remaining for the RO for the door
skymaster is offline   Reply With Quote
Old 03-01-2008, 09:18 PM   #3
Two jacks on each side?
jerryh3 is offline   Reply With Quote
Old 03-01-2008, 10:11 PM   #4
ful king and a jack each end, yes my math was fuzzy eh? lol 53"
oh well damn alzheimer again :}:}
Old 03-02-2008, 06:28 AM   #5
Ok. Just checking. I though that's what you meant.
Old 03-02-2008, 10:32 AM   #6
So... what size header?????
Old 03-02-2008, 10:35 AM   #7
Non load bearing...2X6's.
Old 03-02-2008, 10:42 AM   #8
Thanks for the help. So I need 2 2x6s to cover or can I use a 4x6?
Old 03-02-2008, 09:07 PM   #9
remodeling pro
The 2 x6's with a 1/2" spacer have a much less chance of twisting then a solid 4 x 6 piece of timber.
troubleseeker is offline   Reply With Quote
Old 03-03-2008, 09:34 AM   #10
If this is a non load bearing, closet door, wall ,then no header is needed.
big daddy-o is offline   Reply With Quote
Garage door header sizing rjniles Carpentry 3 01-13-2008 06:57 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 05:15 PM
Header size for wall opening firebirdbd Building & Construction 1 08-07-2007 06:11 PM
Moving Header Supports Star Building & Construction 3 09-25-2005 01:50 AM
