What Kind Of 4x4 Post Shoul I Use For Rail On My Deck? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-13-2009, 10:03 AM   #1
What kind of 4x4 post shoul I use for rail on my deck?
I'm replacing rail on my deck. I found "Trex" composite material on sale(50% off) in home depot, which include, beside other components, composite post sleaves. What kind of 4x4 posts should I use? I will apriciate any suggestion. Thanks
renoet is offline   Reply With Quote
Old 02-13-2009, 10:22 AM   #2
Remodeling Contractor
Use a pressure treated 4 X 4. You will find Trex sleeves might be a little tight. Just shave off each corner of the post so that the sleeve slides on freely. You do not want it too tight.
Old 02-13-2009, 10:28 AM   #3
Thanks Bob. Do I need to stain 4x4 before I put sleave on it?
Old 02-13-2009, 10:31 AM   #4
no. The sleeve will cover and protect the sides. And you use a cap which is glued to the top. Normal post height is 38" off the deck surface. Be sure to use bolts in both directions to fasten the post to the deck framing.
Old 02-13-2009, 10:40 AM   #5
Thanks a lot!
Old 02-13-2009, 08:52 PM   #6
Carpenter
DecksEtc's Avatar
FYI, Trex grows mold.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 02-14-2009, 06:57 AM   #7
Yes that is a good tip. It does so more than most brands. But they make a specific treatment for this. Or use a clear deck stain like Cabot stains. Also a product for cleaning this mold (looks like little black dots on the trek) is "Corte Clean" which is a sodium hypoclorite deck wash.
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
Sagging concrete pool deck Immolate General DIY Discussions 1 06-11-2008 09:16 PM
Are ther alternative to Wooden Post on Deck Foundation herbolaryo Carpentry 2 05-27-2007 07:55 AM
deck post question bigjay1151 Building & Construction 4 11-28-2006 07:13 PM
Deck post footings Outbacker Building & Construction 8 02-11-2006 05:20 PM
