What Is A Good Glue For Wood? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 02:45 PM   #16
the Musigician
DangerMouse's Avatar
Originally Posted by darsunt View Post
I have 'Elmer's Glue All', but is that good enough? Should I get special purpose wood glue?
Of course, Elmer's DOES make excellent carpenter's wood glue. It's just that the "glue-all" is made for many different applications such as paper, ceramic, kid's school projects, etc.
DM
Old 10-17-2011, 05:10 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
the key thing to realize is that different adhesives are for different applications
for wood to wood applications i use typical yellow carpenters wood glue, be it lepages, titebond 2 or gorillas yellow glue. this should be fine for your project. just be sure to let the glue fully set up before re-mounting your doors
if im gluing two different types of materials such as wood to concrete i use pl premium or lumberlock, for plastics and vinyl i use a siding caulking or silicone for exterior use or for small peices of plastic for interior hot melt glue works well
woodworkbykirk is offline   Reply With Quote
Old 10-17-2011, 09:41 PM   #18
liscenced electrician
Rewards Points: 538
if it were me, id fill the hole with fiberglass rather than any wood. But use longer screws, or its going to happen again
jimmy21 is offline   Reply With Quote
Old 10-20-2011, 07:35 PM   #19
Titebond is the best for dowelling. I have tried most of them (Gorilla/Carpenters/3M; etc) and like the consensus above Titebond II or III (Waterproof) works everytime on every project. If you need gapfill drill and dowel or use a mixture of Titebond and sawdust then drill a pilot hole for your screw after it dries. Sounds like you were getting good advice. Good luck.
JimLee_Sr is offline   Reply With Quote
Can I glue down an Armstrong locking hardwood floor? Fixitgeorge Flooring 10 01-30-2013 11:49 AM
glue vs nail hardwood? BlueBSH Flooring 4 04-15-2010 12:48 PM
paint over wallpaper glue? drewhart Painting 5 11-04-2009 03:18 AM
What is a " good construction glue " ? DIYbuddy Building & Construction 3 10-07-2007 08:04 AM
Thread tape vs. Blue glue GT4NE1 Plumbing 9 07-10-2007 10:22 PM
