Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-06-2011, 11:56 PM   #1
What is a good glue for wood?
I want to repair a door where the screws are torn noose from the frame hinges. I plan to drill, install wood dowels, and redrill the screw holes.
What would be a good glue for the wood dowels? I have 'Elmer's Glue All', but is that good enough? Should I get special purpose wood glue? What brands are reliable?
Thanks.
darsunt is offline   Reply With Quote
Old 10-07-2011, 07:07 AM   #2
Moderator
kwikfishron's Avatar
I’d get an actual wood glue for what your doing. Tightbond 2 or 3 are good glues. Tightbond 3 is waterproof so it’s always nice to have around.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 10-07-2011, 07:09 AM   #3
TitebondII yello glue is one I use most often, TitebondIII is a water resistent version.
But if it is the jamb side screws, just replace the screws with 2 1/2-3" screws. They work better because the go into the house framing and reduce or eliminate door sagging problems.
Old 10-07-2011, 02:37 PM   #4
Is this wire Hot?
Oh-Fudge's Avatar
http://www.elmers.com/about/wood-glue
http://www.gorillaglue.com/glues.aspx
or you can try the longer screws like bill said
Oh-Fudge is offline   Reply With Quote
Old 10-08-2011, 12:30 AM   #5
Maintenance
Titebond or gorilla wood glue. That's the two that I personally use.
Steven B is offline   Reply With Quote
Old 10-08-2011, 04:39 PM   #6
I have to agree longer screws are the way to go. Gorilla glue if you must glue
diabloview is offline   Reply With Quote
Old 10-12-2011, 10:33 PM   #7
yep gorilla glue just remember to moisten area to be glued to activate the bonding
brenda o is offline   Reply With Quote
Old 10-14-2011, 10:19 AM   #8
Personally I use Titebond for all my wood glue, works great. Titebond II is my go to, never had any problems with it.
yeag6154 is offline   Reply With Quote
Old 10-16-2011, 11:15 PM   #9
sdsester's Avatar
Gorilla glue fan here too. You could also fill the holes with a suitable epoxy product and skip the dowel part of things.
sdsester is offline   Reply With Quote
Old 10-17-2011, 06:25 AM   #10
the Musigician
DangerMouse's Avatar
I'm sure Gorilla glue has it's purposes, but I do not use it for anything. Tried it, had real bad results. It needs moisture to work??? It foams up and spreads pieces apart unless firmly clamped, and even then, it foams out the edges and needs cleanup after it's "dry"??? No thank you. Use a good WOOD GLUE like Titebond II for best results.
Just my 2 cents.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 10-17-2011, 07:20 AM   #11
Moderator
Just my 2 cents.
DM
Gorilla glue is good stuff imo (although I rarely use it) but all of the issues you mention can be avoided if the user simply would read and fallow the directions on the label.
-NEW MEMBERS-
The Following User Says Thank You to kwikfishron For This Useful Post:
woodworkbykirk (10-17-2011)
Old 10-17-2011, 07:37 AM   #12
the Musigician
Well, of course.
MY experience with it was when it first was introduced, as a wood glue, with NO WARNINGS at ALL on the label about needing moisture, nor anything about swelling/foaming.
DM
Old 10-17-2011, 09:43 AM   #13
In general, another Titebond user here. I am not a great fan of Gorilla Glue, and frankly had thought that it was more gimmick than anything, but have now used it a few times for detail joints with treated lumber, and have found it to perform well. The first time I used it was on an A-frame for an old school house bell, and to maintain a bit of authenticity, got a bit creative with some of the joints for the cross braces, etc., and those joints seem to still be as tight as when I first laid them out. Also, I have a friend who makes very nice jewelry boxes, etc., not magical ones DM, but still very nice, and he uses Gorilla Glue quite often, because he says that his experience has been that it bonds better with certain species of hard woods.
Old 10-17-2011, 10:10 AM   #14
the Musigician
Now THIS I believe. Especially the oilier ones like Brazilian Walnut.
But still, CLAMP IT TIGHT and expect to clean up a little "overflow foam".
DM
Old 10-17-2011, 03:34 PM   #15
Titebond for dowel filling.
Gorilla glue works well when you have a sloppy fit. Your dowels should go in tight.
Also agree with longer screws since this is obviously a problematic area. Filling with dowels is really more for when you change the hinges to something with a smaller screw or a different pattern...
GottaFixIt is offline   Reply With Quote
Can I glue down an Armstrong locking hardwood floor? Fixitgeorge Flooring 10 01-30-2013 12:49 PM
glue vs nail hardwood? BlueBSH Flooring 4 04-15-2010 01:48 PM
paint over wallpaper glue? drewhart Painting 5 11-04-2009 04:18 AM
What is a " good construction glue " ? DIYbuddy Building & Construction 3 10-07-2007 09:04 AM
Thread tape vs. Blue glue GT4NE1 Plumbing 9 07-10-2007 11:22 PM
