What Gauge Finish Nailer To Rent? - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 07:26 PM   #1
Indentured Servant
What gauge finish nailer to rent?
I am installing tongue and groove tamarack on a ceiling. The material is nearly 3/4 inches thick. I don't plan on face nailing. I can rent pretty much any gauge nailer I need. I leaning towards a 16 gauge. I own an 18 gauge but I don't think it is beefy enough to hold the tamarack up tight to the ceiling. I am afraid of spitting too. Any advice or experience?
jackpine is offline   Reply With Quote
Old 11-11-2012, 08:28 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
18 or 16 will work fine.. dabs of construction adhesive on the back will help too
woodworkbykirk is online now   Reply With Quote
Old 11-12-2012, 09:50 PM   #3
Rewards Points: 31
agree, construction adhesive is a good idea and 16gauge would be better nail for this install.
Hardwood Head is offline   Reply With Quote
Old 11-13-2012, 06:18 AM   #4
Indentured Servant
That is two people saying I should use adhesive. Why? What could happen if I don't? Do you think the nails will pull through unless they have a little help?
Old 11-13-2012, 01:50 PM   #5
Rewards Points: 150
No experience, but my advice for 3/4 material would be 15 or 16 gauge. I, too, think that 18 gauge would be too wimpy for this application.
zakany is offline   Reply With Quote
Old 11-13-2012, 01:57 PM   #6
Rewards Points: 13,276
If you skip the adhesive and it fails then what?
I can not imagine renting a trim gun, why not just buy one?
http://www.northerntool.com/shop/too...2747_200582747
Old 11-13-2012, 02:46 PM   #7
AHH, SPANS!!!
Rewards Points: 1,166
Hi, construction adhesive is quick solution to a much better job and in some ways will fill voids behind the material that's being put on the wall/ceiling. put a T&G board placement identifying line across the wall/ceiling so you know where to stop with the glue and not get the stuff all over everything. I worked with a clumsy guy that loved adhesive/caulk anything and had the stuff everywhere!
hand drive is offline   Reply With Quote
Old 11-13-2012, 03:38 PM   #8
18 gauge nailers are used for this by production and precision guys all the time in conjunction with construction adhesive. once the glue cures thats all the holding power you need. just be clean with your work. keep a empty 5 gallon bucket right next to you which you hang the caulking gun on with hte gun to the inside any ooze out just drops into the bucket.. you can throw garbage in that too
theres no real weight to be hung off the panelling just the weight of material itself. for extra holding power with the 18 gauge you can cross nail
The Following User Says Thank You to woodworkbykirk For This Useful Post:
princelake (11-13-2012)
Old 11-13-2012, 06:24 PM   #9
Rewards Points: 512
i have this caulking gun http://www.amazon.com/Contractor-Pro.../dp/B003PNTQS6 and its awesome! it is actually dripless.
princelake is offline   Reply With Quote
Finish nailers pkrapp74 Tools 4 05-20-2012 06:09 PM
Paslode pneumatic finish nailer Ken101 Tools 9 10-23-2011 09:55 AM
Nailers 16 gauge or 18 gauge ? Hexar Tools 2 06-25-2010 11:17 PM
Finish Nailer cibula11 Tools 29 06-11-2007 12:39 PM
What size nailer to use for Soffit Replacement Mach5 Roofing/Siding 2 01-28-2006 12:24 PM
