Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-03-2010, 09:45 PM   #1
What to Fill Hole in the Trim With?
At the bottom of my wall in the living room, in the trim, the previous owner had drilled a hole in it. About the size of a nickel. I don't have the matching trim paint, so i don't plan on repainting it, but what can I buy from home depot or lowes to plug it up for now?
thanks...
also, should you plug up nail holes in the wall with something as well when they are no longer being used? (again i don't have the matching touch up paint color right now).
limitdiy is offline   Reply With Quote
Old 01-03-2010, 09:58 PM   #2
Stick something in the hole that has some resistance, but can be pushed below the surface. A wine cork might do the trick.
Then get lightweight vinyl spackle. I've been using a DAP product. You also need a putty knife. Spread it on and smooth it with the knife.
Use the same thing to fill your nail holes. After it dries, maybe two hours, go back and use your finger to wipe around the holes. The excess will easily rub off the paint, so you'll have a neatly filled hole with no mess around it.
If you mess up, just wipe it with water and it will come right off.
Don't eat it -- read the label first.
I've had good results using ACE hardware to match paint colors if I could take a bit of it into them.
pyper is offline   Reply With Quote
Old 01-03-2010, 10:20 PM   #3
thanks for the info...do you remember what the DAp product is called? Is it called DAP Vinyl Spackle?
Something like this:
http://www.lowes.com/lowes/lkn?actio...yl%20Spackling
Nail hole filler for finished trim work ffgreg Painting 2 09-29-2009 12:21 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Fill hole in hard wood floor in discrete location? pcampbell Flooring 2 05-20-2008 09:23 AM
How much top soil to fill in this hole Malcolm Building & Construction 8 07-27-2007 07:29 AM
