What Drill Bit For A Cable Hole In Lacquered Wood? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 08:37 AM   #1
Question
What drill bit for a cable hole in lacquered wood?
I need to drill a circular or semi-circular hole in a plank of wood that's 0.75in thick "engineered wood" and has a coat of white lacquer. Here's a photo. It would be on the base of it.
The hole would need to be big enough for a grounded power plug. What's the best drill bit to use for something like that? Spade, hole saw...? Any other tips?
benjiprice is offline   Reply With Quote
Old 02-24-2013, 08:42 AM   #2
Rewards Points: 14,306
Is the bottom going to be showing?
If so then only drill 1/2 way through from both sides with a hole saw.
Just take your time when it's starting so there's no tear out. Once it's through the top surface let it rip.
Really should have been drilled before assembly.
Old 02-24-2013, 09:58 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
measure the plug and then use a paddle bit -drilling from the exposed side that you will see later, let any blowout happen in the back...
hand drive is offline   Reply With Quote
Old 02-24-2013, 10:38 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
I would use a hole saw.....and make the hole big enough for one of these.....
Visit Rockler.com for more examples....
And I wouldn't use a paddle bit on that wood....one large enough is going to mess it up.
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
GBrackins (02-24-2013), joecaption (02-25-2013)
Old 02-25-2013, 09:47 PM   #5
Msradell's Avatar
Rewards Points: 338
A paddle bit (Spade bit) is not the correct way to do this. The front of the hole will be rough and the back will be a disaster exhibition point
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Old 02-25-2013, 10:23 PM   #6
Rewards Points: 636
i like the ddawg16 recommendation but when drilling with hole saw or forstner bit place a block of wood tight against other side where drill bit will be coming out this will prevent blow out
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
The Following User Says Thank You to jaydevries For This Useful Post:
ddawg16 (02-25-2013)
Old 02-26-2013, 08:34 AM   #7
AHH, SPANS!!!
if done with enough rpm it will be fine. It is one of the many materials I've drilled through with a paddle bit, work it easy and slow with enough rpm and wa la but for the inexperienced you could be right.
drill hole in new sink zinniachick Plumbing 18 12-30-2012 05:22 PM
Plugging Deadbolt Hole in Solid Wood Door tmex Carpentry 5 09-04-2010 06:55 AM
good drill for big hole saws? jimmy21 Tools 9 09-08-2008 05:10 PM
Allowed to run more than one romex cable through a single hole in a joist? J187 Electrical 7 08-17-2007 08:46 AM
Hollow wood door with hole where the hing plate goes earlc General DIY Discussions 4 07-08-2007 01:21 PM
