What Do You Guys Think Is It Time For New Windows? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-25-2008, 11:56 AM   #1
Question
what do you guys think is it time for new Windows?
Since I'm gutting this whole bedroom. Putting up new insulation and new drywall for the walls and ceiling do you think I should put in new Windows? I can feel drafts coming from both Windows. I would just put in new ones that are the same size. Picture below
This Window looks almost Ancient to me....
what do you guys think is it time for new Windows?-bedroom-upstairs-window.jpg
Tdoggy187 is offline   Reply With Quote
Old 02-25-2008, 12:16 PM   #2
MA licensed remodeler
iremod's Avatar
Look on the bottom of the sashes and see if you can find info about the window. If it doesn't have low-E glass, time for a replacement.
If it does have low-E, just redo the insulation properly to eliminate the drafts and be done with it.
iremod is offline   Reply With Quote
Old 02-25-2008, 12:51 PM   #3
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
Kind of hard to tell from the pics but,
If there is any seal failure in the glass(smokey white appearance)or the window doesn't operate properly,I'd consider replacement.
These seem to be the old mechanically fastened windows which usually came with a 10-15 year warranty on the glass.
The newer vinyl replacements(higher end)have fully welded joints in the frames and sash to cut down on air infiltration,and carry a 20 year warranty because of advances in the construction of the glass panels(warm ege glazing).
Another consideration is the type of valance used for window operation.
The block and tackle system has proven to hold up better over time and is easily available for replacement if needed.
If these windows are 15 years or older, I'd replace them.
oldfrt is offline   Reply With Quote
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 10:34 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 07:32 PM
new windows juliejules4 HVAC 12 12-06-2006 02:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
