What To Do With A Stud That Crowns... - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-25-2010, 09:47 PM   #1
what to do with a stud that crowns...
Title should say it all. Went ot stand my wall up, and realized one of the studs is crowning horribly. I face nailed the top plate. It's a king stud for a door opening. If I face nailed the top half of the stud (that is straight) to the jack stud, will toenailing the bottom of the stud remove the crown?
Tonglebeak is offline   Reply With Quote
Old 03-25-2010, 09:54 PM   #2
Rewards Points: 150
I am not sure I understand the situation properly but if the stud is bowed then I either replace it or cut a slender "V" notch in the stud so that I can straighten it and then face nail another stud to it. If this is a non-bering wall then you can likely nail your jack stud to it and it will perform well without an additional full stud.
TheCamper is offline   Reply With Quote
Old 03-25-2010, 10:17 PM   #3
Yes it's non load-bearing. The king stud is what is crowned (bowed, whichever is the correct term for studs. I know crown is used for joists). I may end up just cutting it off and face nailing another part to it like yous aid.
Old 04-01-2010, 09:32 AM   #4
Old School
Willie T's Avatar
Here's the idea. As seen, you can straighten a stud from either the convex or the concave side (edge).
what to do with a stud that crowns...-straighten-studs-1.jpg   what to do with a stud that crowns...-straighten-studs-2.jpg
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
slickgt1 (04-02-2010)
Old 04-01-2010, 09:41 AM   #5
Originally Posted by Willie T View Post
Here's the idea. As seen, you can straighten a stud from either the convex or the concave side.
i have to say - your sketchup drawings rock, especially for those of us that are visual learners =D
cellophane is offline   Reply With Quote
The Following User Says Thank You to cellophane For This Useful Post:
Willie T (04-01-2010)
Old 04-01-2010, 11:36 AM   #6
Old School
Willie T's Avatar
I'm a big believer in the old adage that a picture is worth a thousand words.
Willie T
Old 04-01-2010, 01:31 PM   #7
Or, remove the bowed stud completely , and replace with a straight one. Remember to always use your straightest material for door,window,and corner framing.
johnrem is offline   Reply With Quote
The Following User Says Thank You to johnrem For This Useful Post:
moorewarner (04-01-2010)
Old 04-06-2010, 01:37 PM   #8
I've never before seen the tactics to getting the bow out of a stud. Those are pretty handy. I normally pull all the bowed studs out and use them for cripples and sills
lanemiller is offline   Reply With Quote
Old 04-09-2010, 02:39 PM   #9
As a side note, it is really helpful if everyone used the proper terms for the proper defects. It does make a difference whether we are talking about a bow or a crown in a board.
Crown=
If board is standing on the narrow edge and both ends are touching the ground, the center will be lifted off the ground.
Bow=
Same condition as above but happens when the board is laying on the wide face.
Cache is offline   Reply With Quote
The Following User Says Thank You to Cache For This Useful Post:
Willie T (04-09-2010)
Old 04-09-2010, 04:11 PM   #10
Old School
Willie T's Avatar
Crown=
Bow=
And "cupping" is...? SEE "CUPPING" HERE.
Willie T
Old 04-09-2010, 06:10 PM   #11
even worse are the twisted studs
Old 04-09-2010, 09:54 PM   #12
No such thing as a twisted stud in my world. The "Cut Pile" fairy magically twinkles them away and they come back as straight and true 15" cripples and blocks.
Old 04-10-2010, 07:50 AM   #13
Framing Contractor
When you have a stud with a bad crown in it notching the stud does not straighten the stud at all. How could it? You now have two sections with a crown. Do the right thing and remove it and put a new one in. Especially since your hanging a door on it. Why start out with something that's not straight.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 04-10-2010, 10:35 AM   #14
Old School
Willie T's Avatar
When, as a GC - not just a framer, you face a job that is due to drywall tomorrow, and a bowed (crowned) stud is discovered, it quickly becomes an issue of expediency and money. Especially if it is a bathroom plumbing wall or one with several runs of wire through it. You have neither the time nor the money to tear out half the plumbing and sometimes all the wiring and have it all redone just to straighten a section of stud.
And if this was somehow possible, to 'do the right thing', all that work would have to also be reinspected.
No, you take the age-old route of straightening the stud in place. If it is all that much of a crown, you cut the stud in several places, and reinforce it.
Willie T
Old 04-10-2010, 12:43 PM   #15
Framing Contractor
We're not talking about all that.
Joe Carola
moving a load bearing stud Tonglebeak Building & Construction 34 07-07-2010 12:32 PM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 01:11 AM
damaged load bearing stud, next to a window danf01 Carpentry 1 10-12-2009 06:02 AM
Is it safe to remove this stud? lofar Remodeling 4 06-16-2009 11:22 PM
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 08:24 PM
