What To Cover Ceiling With Above Wood Stove. - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-14-2008, 03:40 PM   #1
The Big Builder
What to cover ceiling with above wood stove.
Hello All,
I am refinishing the basement. At one end of the basement we have a big wood stove that really cranks out the heat. We love it.
I am currently sheetrocking the walls and will be sheetrocking the ceiling. I plan on placing the fire rated sheetrock in that area but thought I should probably use another covering as well. I was initially thinking about a tin ceiling with a little spacer between the layers.
Any other suggestions? What do you think would look good yet sensible?
Stephen
bigbavarian is offline   Reply With Quote
Old 07-15-2008, 03:04 PM   #2
you might want to get some local eyes on advice. code requirements spacing required from walls etc. and local tried & true fire proof non-combustible coverings. fires are no fun...unless your a pyromaniac.
Big Bob is offline   Reply With Quote
Old 07-15-2008, 03:15 PM   #3
The stove should have a plate on the back that specifies approved clearance on all sides and top. Making a metal shield with spacers will reduce how much heat gets to the ceiling, but unless your ceiling is low, I don't imagine it'll be necessary.
NateHanson is offline   Reply With Quote
Old 07-15-2008, 03:22 PM   #4
The Big Builder
I am up to code on the spacing. I am just looking for somethign that will make it have some character and look good. I was thinking that if I paint the ceiling, over time it will discolor.
Old 07-15-2008, 03:59 PM   #5
Registered User
Termite's Avatar
Provided your flue clearances are up to snuff, I think your idea of a stamped tin ceiling would look pretty nice.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 09:14 AM
wood stove insert Karpol General DIY Discussions 5 11-25-2007 11:56 AM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 05:30 PM
