What Is Better For A Small Room " Junior Loft Or A Full Loft ?" - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 08:17 PM   #1
what is better for a small room " junior loft or a full loft ?"
Thank for the advice with my pc desk
Now i considering to make a loft bed and i have a "donor steel frame" and is modify because i cut off the headboard bracket and add 2x4 at 1ft to raise it up and is came out great
so now since i be getting a $50 GC from home depot i want to put it toward my next project and that is raise my bed to a normal high loft bed would go at 71" from the manufactured and i ran into some concern and i want to see what is the best solution to help me
now my measurement of my room is and please keep in mind is a small room with a oversize closet that is in my room when i first moved
Width under 9ft / Length under 9ft
1.I'm a disabled what best height should i get it cut?
2.I have a box spring should i get rid of it and get a panel wood and cut it and lay it and secure to the bed frame ?
let me know "harold"
irishguy76 is offline   Reply With Quote
Old 05-23-2011, 08:39 AM   #2
Rewards Points: 5,336
How is a disabled person getting into a bed 6 feet off the ground?
How high is the room? Unless it's over 10 feet, the ceiling will be too low.
Ron
Old 05-23-2011, 09:02 AM   #3
Her my thing
My room is small due to this oversize closet that was built when i first move in to my room and my disability is that i suffering from osteoarthritis and is effecting my body including my back and is not like i want a 8ft loft that would be " suicide " i want to make room under my bed so i can put stuff under because i draw up plan and ideal and this is what i might do
make the bed at 3FT because i got a 2 x bookcase and is 2 shelf system and they measure at about 3FT and is give enough clearance room and what do to go in and out of bed "solve it" with this
http://www.homedepot.com/Tools-Hardw...atalogId=10053
and put it side of my bed and the bookcase will be out of the way about under 1" so i have it and get in no problem plus where my 2 bookcase were will make new space so i can have free space and i will most likely keep it that way
Old 05-23-2011, 09:17 AM   #4
If you can convert the frame to a platform bed, you save the extra height.
Your plan sounds fine as long as the bed height is not an issue getting in and out.
Ron
One room cold- what pipes are what...help cciampi HVAC 24 02-20-2011 11:44 AM
Attic full of birds making my room smell Nicholad General DIY Discussions 8 05-31-2009 07:35 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Laying carpet for small exercise room J187 Flooring 10 09-30-2007 08:28 PM
