What is the best way to attach shoe molding to baseboards?
Is that usually nailed in? And then paint over the nails? Or is there some kind of adhesive for it? TIA |
usually it gets nailed to the flooring, not the baseboard. this allows the floor and wall to flex with seasonal changes and you still have a nice clean line where your molding is installed. wood fill would be appropriate for the nail holes but i've seen them caulked as well.
Abe,
I always nail the shoemold to the baseboard and not the floor. Use an 18 gauge brad nailer. With tile floors especially, aim the gun so it is parallel to the tile floor and shoot into the base. You don't want a nail hitting the edge of the tile. On a wood floor, I don't think you would want to nail to the floor. The floor should have some clearance between itself and the walls. That gap should be covered by the base. The shoe is flexible enough to take up any gap between the floor and base. By nailing to the base, the wood floor can move with the seasons and not try to take the shoe with it. Mike Hawkins:) |
I always nail into the baseboard and not the flooring.
I 3rd nailing shoe to baseboard. If you nail it to the floor, you will have gaps that open/close as the flooring expands/contracts, depending on the season. Since you have tile, this is a mute point. Nail to the baseboard, predrill shoe as needed, caulk joint between shoe/baseboard. If one or both are stained, use clear caulk or nothing.
I also had a tile floor and I nailed them to the baseboard.
I did not have the professional tool to do it, so I just put finishing nails in, and filled the holes, sanded, and then painted. |
Mike Hawkins:) |
Yes, very satisfying.
Of all the tools that I used the nail set was my favourite. If I had told my husband that I wanted another power tool, he would had a fit......:laughing: |
Obviously these are moot points when dealing with a tile floor. Wood filler if stained, spackling or painters putty if painted, for the nail holes. Caulking will shrink and leave a dimple at every nail, which will be highly visible when finish coated. |
Another one for nailing to the baseboard.
If painting use autobody filler. It will not suck in, dry quick, and on app is usally enough. Sands easy too. |
Yep, if you nail to the floor, you'll constantly be re-caulking the joint between the base and shoe as the shoe will move with the flooring and not the base. Nail to the base and the two (theoretically) become one piece and move together. I too remember the P.N. and the P.P.M.B. (pre-power miter box) eras. I think that was the P.P.M. (pre-production mindset) era when quality workmanship was more important than just getting the job done.....
There may be a greater variance with a tile floor, but the install is the same. Ron |
| All times are GMT -4. The time now is 03:29 PM. |
