Well Cover - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 05:56 PM   #1
Well Cover
I have an outdoor well on a farm. The pump,inlet, and outlet are underground inside a concrete hole that is 6 feet by 7 feet and 10 feet deep. The walls are 6 inches thick, which leaves a hole 5 feet by 6 feet. I'm trying to come up with a design for a cover for this hole.
This well is on a farm, so how it looks makes no difference. I'm trying to make something that one person can walk on and can be removed easily. I also need something durable.
I'm thinking I'll make a deck like cover, but I don't know what size boards to use for the "joists". Will a perpendicular 2x4 support 300 lbs over a 5 foot span?
kjordan101 is offline   Reply With Quote
Old 08-21-2011, 09:07 PM   #2
Rewards Points: 5,336
Can you make a cover with an access door that can be removed by one person?
Do you need the entire 30 sq ft opening for a reason?
Ron
B. Franklin 1759
Garage Drain Cover matt151617 Plumbing 5 08-09-2011 08:56 PM
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
How to make a Concrete Cover (Lid) for Septic TanK? mezcalero Building & Construction 1 01-15-2010 02:06 AM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 11:23 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
