Weakening Joists With Holes - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 11:34 PM   #1
Weakening Joists with holes
Hi,
I currently have 2x16 16" oc solid wood joists in the basement. There are five to six 3/4" holes already drilled in each joist to run the original electrical, all of them only 1" from the bottom instead of the 2" required for structural integrity. So far after 6o years the floors still haven't caved, but now I need to run new electrical for new lights. I will need to drill two 3/4" holes on each joist.
Does anyone know how many holes I can drill in a joist without further weakening it?
Thanks!
Adatwist is offline   Reply With Quote
Old 02-13-2013, 12:42 AM   #2
oops.. i meant 2x20 joists
Old 02-13-2013, 12:51 AM   #3
GBrackins's Avatar
Rewards Points: 2,108
you are talking about solid sawn lumber that is 2x20?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 02-13-2013, 02:44 PM   #4
Sorry.. type again!! i meant 2x10
Old 02-13-2013, 04:33 PM   #5
GBrackins's Avatar
whew! I was going to say that's some custom framing......
here is the 2009 International Residential Code limitations for notching and drilling of floor joists (your code may vary). This will indicate where (outer 1/3 of the joist span) and sizes allowed in those areas. Just be aware the more holes/notches placed in an area the less strength there will be in the joist.
Hope this helps! Good luck!
Gary
Old 02-15-2013, 12:27 PM   #6
Next Time...New Build
Rewards Points: 150
Can you use any of the existing holes that have already been drilled?
You can always gusset with 3/4 ply/glue/nails over any empty holes to provide some more strength.
RickyBobby is offline   Reply With Quote
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 09:55 PM
cutting 4" holes in 10" floor joist red_cabby Building & Construction 19 06-22-2010 05:25 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 07:41 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 01:48 PM
making holes in the joists to run pipe christy123 Plumbing 5 01-20-2007 04:05 PM
