Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-01-2009, 12:21 PM   #1
Default Ways to support adjustable shelves
I'm planning to build built-in cabinets in my office.Ideally I want an adjustable shelf or two. I'm trying to find a relatively hidden way of having adjustable shelves as opposed to having those big metal rails. I found this photo which is almost identical to what I want http://www.rrsva.com/DSC00113.JPG . I can see holes up the left side where the shelves can be moved to. Are there some brackets that are pushed into those holes, then have a flat area to hold the shelf? I'm thinking that must be what it uses, but I can't find them by searching but maybe I just don't have the right terms. i simply searched things like 'adjustable shelf bracket', etc. Any guidance would be appreciated.
Thanks!
99miles is offline   Reply With Quote
Old 09-01-2009, 01:00 PM   #2
Yes, there is usually a peg that goes in the hole and the shelf rests on it. If you go to Home Depot, Lowes, Staples, IKEA, this is how their adjustable shelves work also. The key will be to ensure your holes are lined up evenly or you will have crooked/wobbly shelves.
Green Giant is offline   Reply With Quote
Old 09-01-2009, 01:07 PM   #3
I went to Lowes and couldn't find them, so I'm wondering what they would be called, or if someone has a link to some. Thanks
Old 09-01-2009, 01:16 PM   #4
the technical name for them is shelf pin. Below is link of those available from Lowes.
http://www.lowes.com/lowes/lkn?actio...Ntt=shelf+pins
Old 09-01-2009, 01:25 PM   #5
Exactly what I was looking for, thank you!
Old 09-01-2009, 07:14 PM   #6
I bought shelf pins at Home Depot - they were in the isle with screws, nuts and bolts.
More On This Topic
Hey, it’s Dominic with expertvillage.com. Both of our brackets are up there very sturdy, not going anywhere very solid into the wall and we got three anchors in each bracket and now it’s time to install the arms. Now the shelves that I got... Read More »
How to Create a Story Pole
How to Create a Story Pole by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip we would be creating our story pole. In our unit here we are going to be putting in 3 shelves on each of the outer sides and then 1 in the center. Now we need them to be going all the way... Read More »
Hey there! This is Dominic with Expert Village and in this segment we’re going to talk about the brackets and shelves. Now if you guys know they got the wire shelf and they have like the little arms that come out of the wall. A lot of pre... Read More »
Hi! My name is Jon on behalf of Expert Village. In this video clip, we will be creating a story pole. Since my bookshelves are going to have adjustable shelves in them, I need to drill a series of holes so that I know where I can put my shelves at. Since... Read More »
Hey, it’s Dominic with Expert Village. Now this guy is almost up guys. I know I might be taking longer it seems like it’s dragging up but believe me this is the most efficient way to put these things up to where they’re not going to... Read More »
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 09:03 PM
Support for 5ft bookcase shelves dbldee20 Carpentry 5 01-07-2009 10:06 AM
Temporarily remove basement support post ColinD Building & Construction 14 12-04-2008 07:07 PM
Extending pantry shelves info@homeworkbydave.com Carpentry 6 10-24-2008 10:57 PM
"Floating" shelves Freelancer Carpentry 7 03-05-2006 10:42 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
