Water Wall Construction - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 02:17 PM   #1
Hello Everyone. I'm finishing my basement which has a rough in for a bathroom. I'm going to install a shower and wanted to know what size wood to use for the water wall frame. I framed the wall for the vent/drain line with 2x6's to accommodate the drain line for the sink. My question is the wall where the shower head will be located, should I frame it out with 2x4's or 2x6's. Thanks for your help.
Daddy is offline   Reply With Quote
Old 05-12-2011, 06:21 PM   #2
In a little over my head
Rewards Points: 706
I'm no plumber, but drain and supply lines have been run inside 2x4 walls for decades.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
Daddy (05-12-2011)
Old 05-12-2011, 07:41 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
2X4 works fine.
2X6 would allow for more sound insulation if that's a concern.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Daddy (05-12-2011)
Old 05-12-2011, 08:21 PM   #4
Rewards Points: 39
FYI, make sure you use nail plates in the walls if you use 2 x 4's.....I believe code requires them for anything closer than 1 1/4 " from the edge of a stud
Sampson is offline   Reply With Quote
The Following User Says Thank You to Sampson For This Useful Post:
Daddy (05-12-2011)
Old 05-15-2011, 03:34 PM   #5
True, but that doesn't mean they ever met code, or meet code today. There are maximum pipe sizes for the standard wall thicknesses. Refer to your local codes.
CraigV is offline   Reply With Quote
Old 05-15-2011, 04:52 PM   #6
If there are no drain or vent lines, you can use 2x4's. But 2x6 will give you more leeway for locating the valve body support brackets and the access door/panel framing.
Old 05-15-2011, 07:41 PM   #7
Thanks everyone for all your input
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
