Water Damaged Underlay - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 09:04 AM   #1
Water damaged underlay
I have water damaged underlay that runs under an exterior wall. the damaged area is about 2 feet wide. I want to cut this piece out, but am unsure what to use to cut the nails that are through the base plate and how best to support the wall when I do. Any do's and don'ts that come with replacing underlay under an exterior wall would be helpful. Thank you to one and all.
kimchee is offline   Reply With Quote
Old 05-16-2011, 09:20 AM   #2
Civil Engineer
Rewards Points: 4,514
By underlayment I assume you mean either plywood, OSB or chipboard. If it is only two feet, and you have a conventionally built stud wall, you are unlikely to need any temporary support for the 3/4 inch piece you are taking out. As for the nails, you can cut right through them with a carbide toothed blade specifically designed for rough lumber, or you can use a Sawzall (my tool of choice for this project) with a nail cutting blade like the Axe. Once you have all the wet underlayment cut out, you should be able to insert a replacement piece. I would use exterior rated plywood for this application.
Tags
exterior wall , replace , underlay
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 03:47 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
