Wallboard - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 11:25 AM   #1
Wallboard
The house we are renting, had wall board installed to finish attic. They didn't mud just laid the wallboard joint taped. We used it as storage and coming thru stairway to low head room caused gashes to the wallboard. How do you fix wholes, and gashes etc. to wallboard? Also the seamed areas the joint tape is warped and cracked, just rip and replace? No money to hire a pro so any help
Lennis is offline   Reply With Quote
Old 09-27-2011, 01:36 PM   #2
Gymschu's Avatar
Rewards Points: 932
Yeah, just rip out the old tape...........if you go to mud over it, you will find yourself very frustrated with bubbles, etc. As for holes and gashes, just use a 4-inch drywall blade, load it up with some joint compound (you won't need much) and skim over the holes at a 45 degree angle so the mud fills the holes. Allow to dry, then apply another coat or two as necessary. Sand, prime, and paint.
Bathroom wallboard hotbread Drywall & Plaster 2 01-30-2011 06:40 PM
Screwing Cementious Wallboard smata67 Building & Construction 2 07-13-2009 09:39 AM
Can Sagging Ceiling Wallboard Be Straightened? MrBill_DIY Building & Construction 4 07-23-2008 01:42 PM
wallboard type analogmusicman Building & Construction 3 02-20-2008 03:24 AM
What type of wallboard? woodeagle Painting 2 01-12-2007 10:53 PM
