Wall Supports - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-01-2007, 08:15 AM   #1
wall supports
My wall supports were removed by by the people that took out a added room in my garage, I call a framer and he said to small of a job for him he would have someone call that can help. not from his business just a friend. he is going to replace them for me for 200 all four corners, he said he would use
dougles furr framing wood. is that good? he s not a framer but doe remodeling . he is going to nail a strip of wood on the wall and then nail the support beam down on that. what do u think< miller
Miller is offline   Reply With Quote
Old 08-01-2007, 09:01 AM   #2
is there drywall covering the wall you are talking about....?
if not....it is really a easy job....
KUIPORNG is offline   Reply With Quote
Old 08-01-2007, 09:09 AM   #3
Wall Supports
there is drywall on the side that conects to the house. I can't see how he removed them , he later patched it. there were only holes in the drywall, could not see it but the other sides are just wood. like all garages. is douglas fur ok? it was sawed off and he wants to nail a wood strip on the wall and nail the support wood down on that , is nails ok or should he use screws? or a metal bracket?
Old 08-01-2007, 10:47 AM   #4
well... sounds like this also involve removing and covering/patching the walls besides framing.... then $200 bucks is real cheap..... I don't think you can go too much wrong.... if he is willing to take the effort to open up the wall... and putting them back... he won't do a lousy job on the frames itself to save a couple of bucks...
Old 08-02-2007, 12:11 PM   #5
Rewards Points: 1,910
I cannot figure out what a "wall support" is. Could you describe what it is your trying to have done in a different way? What is the purpose of these wall supports?
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 04:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
