Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-28-2009, 07:00 PM   #1
Wall Oven Depth Surprise
New to this venue.
Replacing wall oven. New oven depth off by 1/2 inch, width and height perfect. Couple of issues.
1. Found the junction box located in middle of cabinet
2. Double backing on the cabinet equals 3/4 inches in total.
My only option is to cut out the back of the cabinet to form fit. Then reinsert the thin 1/8 inch back board. If so, recommended tool. I have a dremel and jigsaw?
Should I relocate the electrical junction box higher in the cabinet? This would require cutting away the sheet rock, and putting in plywood.
Any and all thoughts helpful.
carusob is offline   Reply With Quote
Old 06-28-2009, 08:02 PM   #2
Tool Geek
PaliBob's Avatar
Dremel has a new Multi Purpose Cutting Kit turns a Dremel into a mini RotoZip
http://www.amazon.com/Dremel-Multi-P...668165-0559915
& Stay Safe
.....Bob Lavery
Old 06-29-2009, 08:57 AM   #3
Appreciate the guidance.
Tags
cabinet, carpentry, oven
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 04:43 PM
Loads on a partition wall acyate Building & Construction 8 03-01-2009 12:02 AM
Kenmore Wall Oven doesn't turn on queen614621 Appliances 1 12-15-2008 05:45 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 01:24 PM
