#1 |
Wall Mounting
I am going to mount an Entertainment System/TV to my wall. It is made from modular cabinets purchased at IKEA. Something VERY similar is posted as an attachment. As in the attached picture, it will be free floating and cover the majority of the wall.
The problem comes with the studs. I want this to be flush with the adjacent wall. In order to do this, each mounting bracket will only cross one stud instead of two. Is this a problem? Can I only have one screw to the stud and an additional two with anchors in the drywall? Is that enough support? |
#2 |
Wall Mounting
Depends on how heavy it is and how the weight will be distributed onto the anchors...
Life's too short...so enjoy it! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to AGWhitehouse For This Useful Post: | PaliBob (07-06-2012) |
#3 | |
It was a dark and stormy
Wall MountingQuote:
Without knowing more I'd put a huge lag screw into the stud and test it to 4x the weight of the device to be mounted. You could then use one drywall anchor just to stabilize this load in the vertical/horiz directions. Don't get on the Evening News. Last edited by Yoyizit; 07-06-2012 at 02:01 PM. |
#4 |
Wall Mounting
A picture showing the suspension rail and how they connect is attached.
It also shows the suggested method of attaching to two studs. Again, the issue is if I shift the mount over it only crosses one. Any other mounting options? |
#5 |
Wall Mounting
Yes. This one just percolated up from my unconscious or preconscious mind.
The steps below are not in order - Put two lag screws through a sheet of plywood, minimum 1/2" thk, one above the other into the stud. The plywood should be slightly smaller than the outline of the TV so you can't see it in back of the TV. Fasten the mounting rail to the plywood. If the center of gravity of the TV and the plywood is not over the stud the lag screws will be torqued by this imbalance but they will hold. Last edited by Yoyizit; 07-06-2012 at 06:13 PM. |
#6 |
Retired Cabinetmaker
Wall Mounting
Having installed thousands of cabinets, I can recommend both the most efficient and strongest way in this situation.
The strongest way is to remove the sheet rock and install 2x4 blocking between each stud, this is what we would insist on in a commercial application. In a residential situation like yours, I would recommend a series of 1x3 cleats running the length of the cabinet at the cabinet anchor points usually under the top panel of each cabinet [but not limited to] A filler or trim piece can be installed at the cabinet finished end to conceal these and make it look presentable. For the TV I would cut a 3/4" thick piece of plywood and install this to the cabinet opening to hold the TV. This can be painted to suit the wall colour. Anchor the flat screen TV to this. Wall anchors are not something I would use for this application. I have learned the hard way from a cabinet becoming dislodged and falling on someone. It's better to be safeer than sorry later.........it cost my insurance company thousands of dollars in compensation. Mike
"I'm not as green as I am cabbage looking" |
| The Following User Says Thank You to woody4249 For This Useful Post: | mae-ling (07-08-2012) |
| Display Modes | |
| How to calculate total glazing allowed in a wall? | dalepres | Building & Construction | 3 | 04-22-2011 01:28 AM |
| Retaining Wall and Muddy Yard | rjschwar | Landscaping & Lawn Care | 10 | 02-24-2010 01:55 PM |
| Temporary wall support question | discojv | Building & Construction | 7 | 01-25-2009 08:23 PM |
| Atlantic-need your opinion on markd's comments about my vapor barrier? | yummy mummy | Building & Construction | 11 | 03-07-2007 10:47 AM |
