Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-07-2008, 03:21 PM   #1
Question wall microwave oven combo install
We took out an old GE (microwave, oven combo) unit and installed a new Frigidare unit. The problem is--the new one has open louvers on the top for ventilation. After talking to the appliance people, all of the new ones do because the microwaves are more powerful now. The guy that installed it did the best he could cleaning up the top sheet rock, however; the stud behind the sheet rock wasn't level. The guy also used some shiney duct tape over the sheet rock, behind the louvers. It really doesn't look very good because the tape is lumpy and again since the cross stud isn't level it's very bad looking.
We have a couple calls out for people with sheet rock skills, but I'm not sure just what to do.
Thanks, Jay
Jaymross@mac.com is offline   Reply With Quote
Old 10-07-2008, 09:36 PM   #2
Thanks, Jay
If your going to just hire someone to fix it, get a couple bids, and check references.
If you considering doing this yourself and want help, then posting some photos would be very helpful.
Jamie
jamiedolan is offline   Reply With Quote
Old 10-07-2008, 11:46 PM   #3
Building codes guy, Mod
thekctermite's Avatar
Sheetrock is easy enough to do, so if you are inclined to do it yourself you've come to the right website. Post a picture if you'd like some help with it.
thekctermite is offline   Reply With Quote
Old 10-08-2008, 07:00 PM   #4
Drywall contractor
Ditto on the pics.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
More On This Topic
So this is where we are going to put the new outlet. I have a stud running down along here or you can find your studs with a stud finder. In an older house a lot of times you can see the nail line running down the wall where they nailed the sheet-rock to... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will be showing you how to install our new siding. Now what you want to do is lift your sheet in place and put in one nail and then you could go ahead and put another nail on the other side... Read More »
Hi! I'm Jennifer Cail and on behalf of Expert Village, I'm going to show you how to clean your microwave from the inside out. Our next step is going to be cleaning the microwave oven rack. This is going to be the same process as cleaning the turn table... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will show you how to prepare our wall studs. On our Styrofoam installation our wall studs fall behind this diamond line. In addition the studs falls where the Styrofoam pieces fit together... Read More »
Hi! I'm Jennifer Cail and on behalf of Expert Village, I'm going to show you how to clean your microwave from the inside out. The first step in cleaning your microwave oven is to look at your owner's manual. This is very important for a number of... Read More »
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 02:05 PM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 06:13 PM
GROUND - Wall Oven - Water Line Acceptable? Mickey53 Electrical 5 09-29-2008 02:02 PM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 02:24 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
