Wall Frames Through An Outlet - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 05:25 AM   #1
Wall frames through an outlet
I'm putting up a chair rail with some faux frames under it. But one of the frames has to go through an outlet. My only idea is to return the frame into the wall on either side of the outlet, any other ideas out there? Pictures would be great. Thanks
Kirk5291 is offline   Reply With Quote
Old 05-04-2011, 07:51 AM   #2
Rewards Points: 5,336
Adjust the frame pattern to avoid the outlet.
Move the outlet.
Eliminate the outlet.
Ron
Old 05-04-2011, 08:25 AM   #3
All Things Design
Personally I would make a box for each outlet that extends the outlet from the wall allowing you to run the wall frames right into it. Looks more natural/professional IMO. You'll need a plastic receptacle extender(as seen in my first pic), Home Cheapo and Blowe's have them. Just make sure the wood is as deep as the thickness of the frames you're using.
Here's how I did mine
Rock8Reno is offline   Reply With Quote
Old 05-04-2011, 11:32 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
umm...what Ron said. Change the layout.
12penny is offline   Reply With Quote
Old 05-04-2011, 11:44 AM   #5
All Things Design
That would work if there was just one outlet, most walls have more than one which would make it more difficult to come up with an acceptable layout.
How do I attach wooden frames to brick wall? martinbudden General DIY Discussions 11 03-09-2011 08:54 AM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 06:17 PM
Code requirements for outlet placement WillK Electrical 8 11-30-2010 09:16 PM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 01:14 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
