-   -   Wall frames through an outlet (http://www.diychatroom.com/f14/wall-frames-through-outlet-103539/)
Kirk5291 05-04-2011 04:25 AM
I'm putting up a chair rail with some faux frames under it. But one of the frames has to go through an outlet. My only idea is to return the frame into the wall on either side of the outlet, any other ideas out there? Pictures would be great. Thanks
Ron6519 05-04-2011 06:51 AM
Adjust the frame pattern to avoid the outlet.
Move the outlet.
Eliminate the outlet.
Ron
Rock8Reno 05-04-2011 07:25 AM
Personally I would make a box for each outlet that extends the outlet from the wall allowing you to run the wall frames right into it. Looks more natural/professional IMO. You'll need a plastic receptacle extender(as seen in my first pic), Home Cheapo and Blowe's have them. Just make sure the wood is as deep as the thickness of the frames you're using.
Here's how I did mine
http://i188.photobucket.com/albums/z...ns/outlet1.jpg
http://i188.photobucket.com/albums/z...ns/outlet2.jpg
http://i188.photobucket.com/albums/z...ns/outlet3.jpg
12penny 05-04-2011 10:32 AM
umm...what Ron said. Change the layout.
Rock8Reno 05-04-2011 10:44 AM
That would work if there was just one outlet, most walls have more than one which would make it more difficult to come up with an acceptable layout.
