Wall Frame And Ducts - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-06-2007, 12:29 PM   #1
Wall frame and ducts
I am finishing my basement. And I am having a small problem i was hoping somebody on here could help me with. You see. Three of the four walls i am doing are clear so i can but up the frame for the wall fine. But then on wall 4 a duct hangs down about 9 inches and i dont know what to do about it. Any help or advice?
KayNyne is offline   Reply With Quote
Old 08-06-2007, 01:05 PM   #2
KayNyne---
You will have to build a soffit around the ductwork. Check out this thread...
http://www.diychatroom.com/showthrea...0438#post40438
You may need to build more soffits to go around any beams or pipes as well.
DIY4EVER is offline   Reply With Quote
Old 08-06-2007, 01:41 PM   #3
But you see. After i did the walls i wanted to do a suspended panel ceiling.
I just need to get the duct that is up agiants the wall.
Old 08-06-2007, 01:52 PM   #4
I am having a bit of a problem getting a good picture of your problem.......You will still need to build a soffit around the duct. You can build it on the wall too if that works better. A suspended ceiling can still be used with the soffit, you will just attach the framing of for the suspended ceilinf to the sides of the soffit.
How would you frame this? [pics] abstracted Building & Construction 45 04-20-2007 08:11 AM
