Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 12-04-2010, 11:27 PM   #1
Lightbulb
wall with coved ceiling
I have an older home (blt early 40's) and I am removing wall between kitchen and dining room I have already removed ceramic tile, incl. cement and wire mesh, the wall I want to remove has a coved ceiling on the DR side - my desire is to remove the cove so both ceilings become one continuous ceiling - I need instructions on how to remove the coved potion of the ceiling - can I cut out the cove with a reciprocating saw or is there a better way of doing this, and is there anyway the corner can be smothed or removed - I am a do it yourself grandmother that doesn't mind getting dirty - any suggestions. thanks pat.
hornbup is offline   Reply With Quote
Old 12-05-2010, 06:47 AM   #2
Moderator
kwikfishron's Avatar
What makes you think you can just remove this wall? It may be a load bearing. What’s above the wall? Are there joist sitting on top of the wall? What do your plans say?
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
Old 12-05-2010, 11:44 AM   #3
Good point raised there!
mrgins is offline   Reply With Quote
Old 12-05-2010, 12:04 PM   #4
I had a contractor verify it was not load bearing - nothing over it and it is opposite of beams in basement - did my homework first - so now fellows what is a girl to do next. thanks pdh
Old 12-05-2010, 05:46 PM   #5
OK Grandma Pat! Good for you! Assuming the cove is wood, use a utility knife to score the paint line horizontally above and below the cove where it touches the wall. Now get a SMALL flat bar and a rigid 6-in-1 paint tool and start prying carefully. Use a hammer to tap the prybars between the moulding...and I mean TAP! You should prepare to patch some small nail holes.
Good luck
Old 12-05-2010, 08:28 PM   #6
thank you so much - now I at least know how to start - will let you know how it goes. I can't wait to attempt this - when I get hung up, I'm a firm beliver in seeking help - "thank you help".
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Crown moulding: Flat ceiling to angled wall question RP31 Carpentry 19 10-30-2012 04:18 PM
Where new wall and "popcorn" ceiling meet klein Drywall & Plaster 2 02-04-2010 01:20 PM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
