-   -   wall with coved ceiling (http://www.diychatroom.com/f14/wall-coved-ceiling-88637/)
hornbup 12-04-2010 11:27 PM
I have an older home (blt early 40's) and I am removing wall between kitchen and dining room I have already removed ceramic tile, incl. cement and wire mesh, the wall I want to remove has a coved ceiling on the DR side - my desire is to remove the cove so both ceilings become one continuous ceiling - I need instructions on how to remove the coved potion of the ceiling - can I cut out the cove with a reciprocating saw or is there a better way of doing this, and is there anyway the corner can be smothed or removed - I am a do it yourself grandmother that doesn't mind getting dirty - any suggestions. thanks pat.
kwikfishron 12-05-2010 06:47 AM
199 Attachment(s)
What makes you think you can just remove this wall? It may be a load bearing. What’s above the wall? Are there joist sitting on top of the wall? What do your plans say?
mrgins 12-05-2010 11:44 AM
Good point raised there!
hornbup 12-05-2010 12:04 PM
coved ceiling
I had a contractor verify it was not load bearing - nothing over it and it is opposite of beams in basement - did my homework first - so now fellows what is a girl to do next.:) thanks pdh
mrgins 12-05-2010 05:46 PM
OK Grandma Pat! Good for you! Assuming the cove is wood, use a utility knife to score the paint line horizontally above and below the cove where it touches the wall. Now get a SMALL flat bar and a rigid 6-in-1 paint tool and start prying carefully. Use a hammer to tap the prybars between the moulding...and I mean TAP! You should prepare to patch some small nail holes.
Good luck
hornbup 12-05-2010 08:28 PM
thank you so much - now I at least know how to start - will let you know how it goes. I can't wait to attempt this - when I get hung up, I'm a firm beliver in seeking help - "thank you help".
