Wainscoting And Crown Moulding With Unlevel Floors - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 12:10 PM   #1
Wainscoting and crown moulding with unlevel floors
I recently purchased a home with a concrete slab foundation. We want to install beadboard wainscoting and crown molding. In some rooms the slab has quite a slope (3.75" in 29 feet) and we're not sure whether the wainscoting should follow the floor, or be installed so that it's actually level. The ceiling matches the floor so that it's always 98.5" from the floor. I'm afraid that if I install the wainscoting to be parallel with the floor the vertical lines of the beadboard will be visibly out of plumb and just look unlevel to the eye. On the other hand, I don't think it would look good to have the wainscoting almost 4" higher on one side of the room (one continuous wall) and not parallel with the crown molding.
Advice and/or opinions are appreciated.
BobSmitt is offline   Reply With Quote
Old 08-04-2011, 12:25 PM   #2
kwikfishron's Avatar
Rewards Points: 794
Welcome to the forum.
I’d measure from the ceiling down to the top of the wainscoting on either end of the wall, snap a caulk line and go with that. A level line would stand out like a sore thumb.
kwikfishron is online now   Reply With Quote
Old 08-04-2011, 12:39 PM   #3
Rewards Points: 150
If you start the wainscoting on the floor at the high end of the room and run it level, by the time it gets to the other end of the room there will be a 3.75" gap. Then run 4" or greater baseboard across the room and it will hide the gap. Much more important that the wainscoting is level.
Broughton is offline   Reply With Quote
Old 08-04-2011, 01:01 PM   #4
my question is why is the floor that far off of level?
Old 08-23-2011, 10:59 AM   #5
It's earthquake country and this concrete foundation has lived through two magnitude 7.0+ earthquakes occurring within 10 miles in its lifetime. Seismic activity on a cut and fill hillside lot will do that. I imagine that's the main reason for the slope.
What Size Crown Molding? Jim McClain Interior Decorating 1 10-04-2010 07:16 AM
