Wainscoating - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-08-2012, 02:53 PM   #1
wainscoating
What heights do Wainscoating primed pieces come in? Thanks
dfarago is offline   Reply With Quote
Old 03-08-2012, 03:54 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
I believe the standard height for a "kit" is 32 inches.
hyunelan2 is offline   Reply With Quote
Old 03-08-2012, 07:29 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
depends on what your looking to achive.. if your looking at installing v-groove style wainscotting or bead board you can get it in 32" tall or 8' which you cut to the length you need. theres also 4x8 sheets that you can get
the general rule of thumb is that the top of it should be 1/3 the total height of the wall.. in much older homes it can be 2/3 but works best if the ceiling is 9' high or greater if not it makes the space feel much smaller
woodworkbykirk is offline   Reply With Quote
Old 03-09-2012, 01:46 PM   #4
Was recently in an older home with high ceilings. It had very tall wainscoating (wasn't bead boad) with a small shelf around the top. Looked pretty smashing to me. I know is was over 6 feet as I couldn't see the top of the small shelf and the ceilings were at least 10 feet.
Mike in Arkansas is offline   Reply With Quote
DVD shelves above wainscoating? Morgan19 Home Theater 1 10-08-2011 10:40 AM
Georgia Pacific Ply-Bead for wainscoating? Badfish740 Carpentry 6 01-15-2011 04:45 PM
wainscoating look alike krissycraytor Drywall & Plaster 2 09-10-2010 11:05 AM
Need Help with Wainscoating Top Cap (chair rail) RickDel Carpentry 5 06-30-2010 02:22 AM
removing glued wainscoating diysteph General DIY Discussions 4 07-16-2007 05:38 AM
