Vinyl Siding Over Lap Siding - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-05-2011, 07:04 PM   #1
Rewards Points: 107
Vinyl siding over lap siding
Thinking about putting vinyl siding on my garage. It is 8" wood lap siding now. I have done siding before but it was on new construction. I would like to leave the wood siding on, put foam board it and then the vinyl. My question is what to do with the windows? They will be sunk in 1 1/2" or so. TIA
thunderhead is offline   Reply With Quote
Old 06-06-2011, 07:06 AM   #2
Rewards Points: 5,336
You would extend the frame out to the new siding plane. Just like installing jamb extensions on the interior to line up with the finished wall.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Tom Struble (06-06-2011)
Old 06-07-2011, 09:30 PM   #3
My house when I bought it had aluminum siding over top of the wooden clap board.
For the windows and the doors they formed a flashing for around the opening.
In much the same manner as is done when replacement windows are installed.
Old 06-08-2011, 09:39 PM   #4
Custom Home Builder
Not a very good idea.
Why would you go through all that trouble for residing a garage?
Plus, it's your own home.
I would strip the old lap off, make sure you have a good water barrier and then install the vinyl.
Why not??
Will eliminate the window problem and the whole garage will look so much better!
thomasjmarino is offline   Reply With Quote
Old 06-08-2011, 10:02 PM   #5
Not a Noob or Boob
Why not??
I agree with all but putting vinyl on anything. It looks like garbage! It looks cheap and if not installed properly you can have a nasty looking outcome in a year or two. Put wood back up! Looks better and will maintain it's value in the long run.
Rob1975 is offline   Reply With Quote
Old 06-08-2011, 10:56 PM   #6
Why not??
On my garage the wooden clap forms the wall sheeting. If it were to be pulled off, all that would be left, would be bare studs.
In 1948 constructrion methods were not the same as now!
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
Insulated Vinyl Siding vs Regular Vinyl Siding DIY828 Remodeling 25 08-06-2009 12:32 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
